[OpenLayers-Users] vector layer visibility or z-order with image layer
MilesTogoe miles.togoe at gmail.com
Tue Feb 26 12:51:25 EST 2008
Christopher Schmidt wrote:
> On Tue, Feb 26, 2008 at 02:51:21AM -0700, MilesTogoe wrote:
>> I'm now working with svn trunk as it seems to fix some previous issues
>> and my image layer is now correctly bounded, projected with long/lat  -
>> however, if I have an image layer and add a vector layer, the vector
>> features are not showing and the vector layer is "grayed" out in the
>> layer switcher.  If the layers are added as such:
>> map.addLayers([graphic,vlayer]);
>> the vector layer should be on top, correct ?  Does some visibility
>> switch need to be set ?  Any ideas ?
> I bet you're setting your maxExtent, maxResolution, etc. on the image
> layer and not on the map. If so, either 1. set them on the map as well,
> or 2. set them on the vector layer as well.
Thks for the tip.  On the image we set the projection and bounds but
didn't use maxExtent or maxResolution - but we'll experiment on setting
some settings to the vector layer or map as well.
> Regards,
