[OpenLayers-Users] Trying out the new Mapguide Layer support in the dev branch
Zac Spitzer zac.spitzer at gmail.com
Thu Feb 28 19:55:24 EST 2008
ok, got it working, i was doing a late night session
On Fri, Feb 29, 2008 at 11:08 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> I'm just playing with the mapguide sample, i'll have another look and
>  post my results
>  on a side note, I just checked, an anonymous user can return the
>  mapDefinition as a json response,
>  could we make the mapguide provider auto configure itself with default
>  bounds and scale ranges using
>  the following kind of request?
>  also, is it possible to inject addtional url params into the request
>  (ie &USERNAME=Anonymous)
>  /mapguide/mapagent/mapagent.fcgi?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&RESOURCEID=
>  Library%3A%2F%2FSamples%2FSheboygan%2FMapsTiled%2FSheboygan.MapDefinition&FORMAT=application%2Fjson
>  z
>  On Fri, Feb 29, 2008 at 7:30 AM, Mike Adair <madair at dmsolutions.ca> wrote:
>  > I just tested by creating a tiled version of the Sheboygan sample
>  >  dataset with 8 zoom levels and it worked fine:
>  >  var extent = new
>  >  OpenLayers.Bounds(-87.865114442365922,43.665065564837931,-87.595394059497067,43.823852564430069);
>  >  var tempScales =
>  >  [20000000,440142.04206,96862.50859,21316.63117,4691.17279,1032.39118,227.19938,50];
>  >  var mapOptions = {
>  >        maxExtent: extent,
>  >        scales: tempScales,
>  >        units: 'dd',
>  >        projection: 'EPSG:4326'
>  >  map = new OpenLayers.Map( 'map', mapOptions );
>  >  The bounds being used come from the Map object so I'm wondering if you
>  >  set up the map correctly?  Projection or units perhaps?  If not, is it
>  >  possible to have a look at your test case?
>  >  Mike
>  >  Zac Spitzer wrote:
>  >  > I have been testing out the new mapguide support -
>  >  > http://trac.openlayers.org/ticket/995
>  >  > It works well with non tiled images for me, however, I have been
>  >  > unable to get the tiled images to work
>  >  > I have set my bounds for Australia to match my mapDefinition
>  >  > var extent = new OpenLayers.Bounds(112.931740,-43.587490,153.632810,-8.933330);
>  >  > but the tiles don't come up, the request GETTILEIMAGE request looks fine.
>  >  > when i dump the bounds being passed into calculateGridLayout in Mapguide.js
>  >  > left-bottom=(-395.8841059168209,-390.06229688031436)
>  >  > right-top=(662.4486559168209,337.5414768803144)
>  >  > I have just been playing the the example file.
>  >  > z
>  Zac Spitzer -
>  http://zacster.blogspot.com (My Blog)
>  +61 405 847 168
Zac Spitzer -
+61 405 847 168
