[OpenLayers-Users] MediaWikia
Robert J Becraft castlewrks at hughes.net
Tue Jan 8 17:32:01 EST 2008
Erik,
Yes, it is up at:
http://www.metaphaze.com/AvalonWikia/index.php5?title=AvalonMap
All the layers work and the Semantic markup on the country pages
provides some junk to come up when you click on the markers. Matt was
great help in getting it to work.
Robert.
Erik Uzureau wrote:
> Hi Robert,
> Just a quick note... did you ever manage to get this working?
> I'm hunting for more examples to help people use OpenLayers
> in different contexts..
> Erik
> On 11/3/07, Robert J Becraft <castlewrks at hughes.net> wrote:
>> Matt Williamson wrote:
>>> Robert,
>>> I'm the author of the extension Christopher mentioned (thanks!). Yes,
>>> check it out, and also the demo wiki at http://s89238293.onlinehome.us/w/
>>> If you need any help, let me know. The extension also relies on
>>> another MediaWiki extension called Semantic MediaWiki, which I highly
>>> recommend anyway. Currently it requires version SMW 0.7, but I've
>>> officially started work on the modifications necessary to make it work
>>> with SMW 1.0--I hope to have the update out by the end of November or so.
>>> Let me know if you have any questions or need any help with it!
>>> -Matt
>> Hello Matt,
>> I got the simple example up and running... I'm now trying to understand
>> your documentation and convert my map at
>> http://www.metaphaze.com/Avalon/AMII_world_map.htm to my wiki page.  I
>> think I blew a gasket trying to follow the documentation.
>> You have (I believe), two different components mixed together in your
>> descriptions... part of the setup requires an understanding of the
>> Semantic_MediaWiki extension and the second part is how your extension
>> uses that setup to do its part of putting the map together and adding
>> the elements.
>> It would be a great help if you could walk me through this process once
>> so that I can get the gist of it.
>> Regards,
>> Robert J Becraft
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
