[OpenLayers-Users] TileCache works when used through wms layer
but not as a TileCache Layer
Lance Dyas
lancelot at inetnebr.com
Fri Jan 11 18:54:46 EST 2008
So everybody knows I found the problem the clone method of
TileCache.Layer is not sending the layername correctly
so Overview Map is getting the options object in place of
the layername.
Christopher Schmidt wrote:
> On Thu, Jan 10, 2008 at 11:51:27PM -0600, Lance Dyas wrote:
>> The fix is great and the tilecache layer is working nicely ... but isnt
>> there always a but...
>> this is probably an easy one.. ;-) the overview map now isnt recognising
>> the
>> layer name properly in the urls it requests...
>> http://www.dyasdesigns.com/tiles/%5Bobject%20Object%5D/08/000/000/000/000/000/000.png
>> http://www.dyasdesigns.com/croatia/zagrebopen2.htm
> Without looking at your code, it sounds like you've got an object where
> a string is expected. Might double check that you're sending the right
> parameters.
> Regards,
