[OpenLayers-Users] Google doesn't line up with other WMS
Yves Jacolin
yjacolin at free.fr
Sat Jan 12 08:24:17 EST 2008
Did you check that this EPSG code exist in your epsg file?
Did you adapt your code to the new projection ('SphericalMercator')?
Sorry, I can not help you so much.
Y.
Le samedi 12 janvier 2008 14:14, Cranio a écrit :
> Thanks Yves but still doesn't work.
> When sphericalMercator is true, I get wrong centering (but this may be
> to the mismatched proj'n) but I lose also all the drag capabilities, and
> zoom seems to zoom in the wrong area.
> Also, my mapfile has this header:
> PROJECTION
> "init=epsg:26592"
> END
> If i change it to epsg:900913 (or whatever google uses, I don't remember
> now)
> my map simply won't shop up, with non error.
> Any ideas?
> Yves Jacolin wrote:
> > Le samedi 12 janvier 2008 12:20, Cranio a écrit :
> > [cut]
> >> So, I guess, I have projection issues, but I am lost between how to
> >> define:
> >> - the Mapserver Mapfile projection (now served as epsg:26592)
> >> - the single layers in mapfiles projections (now undeclared)
> >> - the Openlayers map projection (I believe that, now in my test
> >> programs, it is default epsg:4632)
> >> to have Google or Yahoo WMS maps correctly line up with mine.
> >> Any help appreciated and sorry for the newbie question :)
> > Hi,
> > You need to use 'SphericalMercator' parameter in your map option and in
> > your
> > google options, See http://trac.openlayers.org/wiki/SphericalMercator for
> > correct information ;)
> > Y.
> > Yves Jacolin
> > http://yjacolin.gloobe.org
> > http://softlibre.gloobe.org
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
Yves Jacolin
