[OpenLayers-Users] Possible pink tile fix
Eric Lemoine
eric.c2c at gmail.com
Sun Jan 13 09:28:45 EST 2008
On Jan 11, 2008 7:12 PM, Ben Brehmer <bbrehmer at refractions.net> wrote:
> Hello all,
> I just wanted to throw this out there as it might be useful to others;
> We'd been having some problems with pink tiles, even with
> IMAGE_RELOAD_ATTEMPTS set to a large number (10). The tile reload would
> max out and the tile still wouldn't load properly in IE6 & 7. But adding
> a dynamic dummy parameter to the problem images' URL seems to have
> solved the problem.
> In the Util.js::onImageLoadError() function we simply modify the src of
> the tile:
> var tmp_src = this.src;
> this.src = tmp_src+"&retry="+this._attempts;
> This allows you to monitor how many times an image fails to load from
> your server logs as well.
Ben,
Thanks for sharing this thing. Was your problem related to some cache
effect in IE?
Eric
