[OpenLayers-Users] getFeatureInfo request in new window + new map?
Maria Panagou snowdrop at ath.forthnet.gr
Tue Jan 22 19:57:42 EST 2008
is it possible to use variable substitution in a layer creator url,in a
header template file (getfeatureinfo) such as:
 var quakes = new OpenLayers.Layer.WMS( "Óçìáíôéêïß Óåéóìïß",
                       "http://127.0.0.1/cgi-bin/mapserv.exe?",
                        {map: '../htdocs/mpanagou/Quakes1local.map',
                          layers: 'Quakes',ID=[codee]
						  transparent: true},
                          {isBaseLayer:false, singletile:true, reproject:
true});
where ID is filter condition, [codee] attribute from getfeatureinfo.
in map file, layer quakes is defined by:
DATA "pos FROM (select * from public.quake_small where codee1=%ID%) as foo
using unique codee1 using SRID=4326"
in OL, the declaration of quakes as following works:
                          layers: 'Quakes',ID=721
						  transparent: true},
true});
but i want id to be set dynamically as the value of codee attribute returned
by getfeatureinforequest
thank you
View this message in context: http://www.nabble.com/getFeatureInfo-request-in-new-window-%2B-new-map--tp15009098p15032612.html
