[OpenLayers-Users] Problem wth ScaleBar
David R Robison drrobison at openroadsconsulting.com
Mon Jan 28 16:37:08 EST 2008
Found the problem. I have 10 style sheets loaded into the application.
When processing the first, the access to cssRules through the error:
NS_ERROR_DOM_INVALID_ACCESS_ERR. This error caused the other style
sheets to be ignored. If I replaced the "break" in the catch block with
"continue", all was well. David
Tim Schaub wrote:
> Hey-
> Tim Schaub wrote:
>> Hey-
>> Can you send me a bit more context?  If you can't provide a link to a
>> live site, but can send a page (or pages), send directly to me.
> Sorry, and browser info.
>> Thanks,
>> Tim
>> David R Robison wrote:
>>> It looks like I have the right code. I think the problem is with the
>>> styleValue routine. I have had to modify the following code in the draw
>>> function:
>>>         var vertDisp = 0;
>>>         for(var classIndex = 0; classIndex < classNames.length;
>>> ++classIndex) {
>>>             var cls = classNames[classIndex];
>>>             vertDisp = Math.max(
>>>                 vertDisp,
>>>                 this.styleValue(cls, 'top') + this.styleValue(cls, 'height')
>>>         if (vertDisp == 0) vertDisp = 30;
>>> The vertDisp value was coming out to be zero. By adding the last line
>>> and setting it to 30 it helped, but the bar still looks a bit off. I
>>> load a number of style sheets and I think that there is an issue with
>>> one that is causing the problem. I suspect the following code in styleValue:
>>>                         if(typeof(sheet.cssRules) == 'undefined') {
>>>                             if(typeof(sheet.rules) == 'undefined') {
>>>                                 // can't get rules, assume zero
>>>                                 break;
>>>                             } else {
>>>                                 allRules = sheet.rules;
>>>                         } else {
>>>                             allRules = sheet.cssRules;
>>> I am wondering if the "break;" should be a "continue;"? Any thoughts? David
>>> Tim Schaub wrote:
>>>> Hey-
>>>>> I was using the one in the tschaub sandbox. David
>>>> If you take a look at the patch for the scale bar, you'll see there are
>>>> some changes required to the default stylesheet.
>>>> http://trac.openlayers.org/attachment/ticket/24/scalebar.patch
>>>> In addition, you'll want to add your stylesheet with a link tag instead
>>>> of relying on the default dynamically added stylesheet.
>>>> <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
>>>> Thanks for trying it out.  Write back if you still have any trouble with it.
>>>> Tim
>>>>> Christopher Schmidt wrote:
>>>>>> On Mon, Jan 21, 2008 at 06:43:27PM -0500, David R Robison wrote:
>>>>>>>  I am trying to get the OpenLayers.Control.ScaleBar working. I've added
>>>>>>> it to my map according to the example html. However, when my map draws,
>>>>>>> I get the units (in my case 'miles') but it displays at the bottom of
>>>>>>> the map and I get no scale bar. Its as if the scale bar is below the map
>>>>>>> and hidden. Any thoughts on how to get this to work correctly? Thanks, David
>>>>>> Are you adding ScaleBar (which isn't in trunk) or Scale()? OpenLayers
>>>>>> does not currently have a ScaleBar control.
>>>>>> Regards,
>>>>> David R Robison
>>>>> Open Roads Consulting, Inc.
>>>>> 708 S. Battlefield Blvd., Chesapeake, VA 23322
>>>>> phone: (757) 546-3401
>>>>> e-mail: drrobison at openroadsconsulting.com
>>>>> web: http://openroadsconsulting.com
>>>>> blog: http://therobe.blogspot.com
>>>>> book: http://www.xulonpress.com/book_detail.php?id=2579
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>>> David R Robison
>>> !DSPAM:4033,479e3dc020313362379201!
>> Users mailing list
>> !DSPAM:4033,479e436033035219720167!
> Users mailing list
David R Robison
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080128/087b0bbb/attachment.html
