[OpenLayers-Users] Problem wth ScaleBar
Tim Schaub tschaub at openplans.org
Mon Jan 28 16:46:03 EST 2008
Hey-
David R Robison wrote:
> Found the problem. I have 10 style sheets loaded into the application.
> When processing the first, the access to cssRules through the error:
> NS_ERROR_DOM_INVALID_ACCESS_ERR. This error caused the other style
> sheets to be ignored. If I replaced the "break" in the catch block with
> "continue", all was well. David
Yeah, I guessed it was something like that.  Can you mention the name of
your browser?  And perhaps give an indication of how your stylesheets
are included/linked?  Do any of your stylesheets have no rules in them?
  I'm curious to see where sheet.cssRules is undefined for one
stylesheet but not the next.
The patch for #24 is updated.  Thanks for any more info.
Tim
> Tim Schaub wrote:
>> Hey-
>> Tim Schaub wrote:
>>> Hey-
>>> Can you send me a bit more context?  If you can't provide a link to a
>>> live site, but can send a page (or pages), send directly to me.
>> Sorry, and browser info.
>>> Thanks,
>>> Tim
>>>> It looks like I have the right code. I think the problem is with the
>>>> styleValue routine. I have had to modify the following code in the draw
>>>> function:
>>>>         var vertDisp = 0;
>>>>         for(var classIndex = 0; classIndex < classNames.length;
>>>> ++classIndex) {
>>>>             var cls = classNames[classIndex];
>>>>             vertDisp = Math.max(
>>>>                 vertDisp,
>>>>                 this.styleValue(cls, 'top') + this.styleValue(cls, 'height')
>>>>         if (vertDisp == 0) vertDisp = 30;
>>>> The vertDisp value was coming out to be zero. By adding the last line
>>>> and setting it to 30 it helped, but the bar still looks a bit off. I
>>>> load a number of style sheets and I think that there is an issue with
>>>> one that is causing the problem. I suspect the following code in styleValue:
>>>>                         if(typeof(sheet.cssRules) == 'undefined') {
>>>>                             if(typeof(sheet.rules) == 'undefined') {
>>>>                                 // can't get rules, assume zero
>>>>                                 break;
>>>>                             } else {
>>>>                                 allRules = sheet.rules;
>>>>                         } else {
>>>>                             allRules = sheet.cssRules;
>>>> I am wondering if the "break;" should be a "continue;"? Any thoughts? David
>>>> Tim Schaub wrote:
>>>>> Hey-
>>>>>> I was using the one in the tschaub sandbox. David
>>>>> If you take a look at the patch for the scale bar, you'll see there are
>>>>> some changes required to the default stylesheet.
>>>>> http://trac.openlayers.org/attachment/ticket/24/scalebar.patch
>>>>> In addition, you'll want to add your stylesheet with a link tag instead
>>>>> of relying on the default dynamically added stylesheet.
>>>>> <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
>>>>> Thanks for trying it out.  Write back if you still have any trouble with it.
>>>>> Tim
>>>>>> Christopher Schmidt wrote:
>>>>>>> On Mon, Jan 21, 2008 at 06:43:27PM -0500, David R Robison wrote:
>>>>>>>>  I am trying to get the OpenLayers.Control.ScaleBar working. I've added
>>>>>>>> it to my map according to the example html. However, when my map draws,
>>>>>>>> I get the units (in my case 'miles') but it displays at the bottom of
>>>>>>>> the map and I get no scale bar. Its as if the scale bar is below the map
>>>>>>>> and hidden. Any thoughts on how to get this to work correctly? Thanks, David
>>>>>>> Are you adding ScaleBar (which isn't in trunk) or Scale()? OpenLayers
>>>>>>> does not currently have a ScaleBar control.
>>>>>>> Regards,
>>>>>> David R Robison
>>>>>> Open Roads Consulting, Inc.
>>>>>> 708 S. Battlefield Blvd., Chesapeake, VA 23322
>>>>>> phone: (757) 546-3401
>>>>>> e-mail: drrobison at openroadsconsulting.com
>>>>>> web: http://openroadsconsulting.com
>>>>>> blog: http://therobe.blogspot.com
>>>>>> book: http://www.xulonpress.com/book_detail.php?id=2579
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>> Users mailing list
>>>> David R Robison
>>> Users mailing list
>>> !DSPAM:4033,479e436033035219720167!
>> Users mailing list
> David R Robison
> !DSPAM:4033,479e4b1f56767082231907!
