[OpenLayers-Users] SLD file and labels
Tim Schaub tschaub at opengeo.org
Thu Jul 10 17:32:00 EDT 2008
Hey-
hcan-hcan wrote:
> Hi!
> I'm using the label examples from camptocamp's sandbox (vectors-with-text).
> Works just fine! Now I have started to  create some themes using and  SLD
> xml file, the same way as in the Styled Layer Descriptor (SLD) Example. Is
> there a way to get the labels working using an SLD file? What I had in mind
> was something like this:
> <sld:CssParameter name="label">
> 	<ogc:Literal>name: ${name}</ogc:Literal>
> </sld:CssParameter>
> <sld:CssParameter name="fontColor">
> 	<ogc:Literal>red</ogc:Literal>
> </sld:CssParameter>
> <sld:CssParameter name="fontWeight">
> 	<ogc:Literal>bold</ogc:Literal>
> </sld:CssParameter>
The SLD spec includes an sld:TextSymbolizer element.  This element has
optional children sld:Font, sld:Label, and sld:Fill - all of which are
supported (in the writers) as of http://trac.openlayers.org/changeset/7333.
If the SLD parser is given a symbolizer keyed by 'Text', it will write
In OpenLayers a text symbolizer should have the following properties:
label, fontFamily, fontSize, fillColor, fillOpacity
(We can add in support for fontStyle and fontWeight.)
It would be great to get the vectors labeling stuff in the trunk - and
we should make sure we're following the same conventions for describing
a text symbolizer.
Tim
> However, I could not get it working. Does anyone know if this is possible?
> Or has another solution...
> Thanks,
> //H
