[OpenLayers-Users] Layer.Text
Eric Lemoine
eric.c2c at gmail.com
Wed Jul 23 02:34:45 EDT 2008
Hello. You need to create a GML layer object by passing the
constructor the url to your text file and in the options object the
text format class to be used for parsing
(format:OpenLayers.Format.Text)You're right that having an example on
that would be useful. A ticket and a patch for that would be welcome
:) Cheers. Eric
2008/7/22, Matt Williamson <MatthewDW at gmail.com>:
> Hello list,
> I've seen posts on this list that suggest no longer using Layer.Text,
> but instead using Layer.GML with Format.Text and a selectFeature
> control (I think I got all that right). Though I'm not seeing so far
> exactly how all those are supposed to go together. Could somebody post
> a basic example of this? I could probably hack something together, but
> I'd like to see the preferred/elegant way to do it.
> In fact, if this is now the preferred method, and using Layer.Text is
> deprecated (or at least discouraged), could the markersTextLayer.html
> example on openlayers.org be changed to reflect the new method (or an
> additional example be made) to demonstrate the new approach?
> Thanks!
> -Matt
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
