[OpenLayers-Users] Getting jumbled tiles from tilecache server
Christopher Schmidt crschmidt at metacarta.com
Wed Jul 23 15:21:48 EDT 2008
On Thu, Jul 24, 2008 at 12:45:40AM +0530, Sanjiv Singh wrote:
> Hi all,
> I have setup a tilecache server which serves OpenStreetMap Data using
> Mapnik. I am using the following code to read from the tilecache
> server:
Do you have the 'tms_type=google' option on? If so, turn it off...
Otherwise, yes, send this to the TileCache mailing list with your
tilecache.cfg included.
> function init(){
>     map = new OpenLayers.Map('map', {
>                       projection: new OpenLayers.Projection("EPSG:900913"),
>                       displayProjection: new OpenLayers.Projection("EPSG:4326")
>     osm = new OpenLayers.Layer.TileCache( "OSM Layer",
>                     ["http://localhost:8080/tiles"], "osm");
>     map.addLayer(osm);
>     map.setCenter(new OpenLayers.LonLat(0, 0).transform(new
> OpenLayers.Projection("EPSG:4326"), new
> OpenLayers.Projection("EPSG:900913")), 0);
> I am able to get the map from the server. But as I keep zooming in, I
> can see only jumbled tiles. I had used the spherical mercator option
> when importing OSM data using osm2pgsql. My mapnik is working properly
> as I am seeing the tiles generated by generate_tiles.py correctly in
> openlayers using the OpenLayers.Layer.OSM.Mapnik layer.
> What am I doing wrong ? Should I post this in tilecache ML too?
> Regards
> Sanjiv
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
