[OpenLayers-Users] Zooming with multiple kamap layers
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sat Jul 26 04:58:31 EDT 2008
Ok - here's a better demonstration of this problem. Copy this into an
html file...open it in a browser, then zoom in. You'll see what I'm
talking about. This is using the World Map and Places layers from one
of the ka-map demos hosted by omniverdi.org. Is it something I'm doing
wrong with the OL code, or maybe a bug in OL's kamap layer object?
Regards,
Mike
<html>
<head>
<title>OpenLayers Example</title>
<script
src="http://www.openlayers.org/api/OpenLayers.js"></script>
</head>
<body>
<div style="width:100%; height:100%" id="map"></div>
<script defer="defer" type="text/javascript">
var options = {
maxExtent: new OpenLayers.Bounds(-180,-90,180,90),
scales:
[100000000,50000000,25000000,10000000,5000000,2500000,1000000],
numZoomLevels: 8,
tileSize: new OpenLayers.Size(200,200),
projection: "EPSG:4326",
units: "dd"
var map = new OpenLayers.Map('map',options);
var ly1 = new OpenLayers.Layer.KaMap("World Map",
"http://clima.ominiverdi.org/ka-map/htdocs/tile.php",
{i:"JPEG",map:"cvs",g:"World Map",version:"6"}
var ly2 = new OpenLayers.Layer.KaMap("Places",
{i:"PNG",map:"cvs",g:"Places",version:"6"}
map.addLayers([ly1,ly2]);
map.zoomToExtent(new OpenLayers.Bounds(-180,-90,180,90));
ly2.setVisibility(true);
</script>
</body>
</html>
Mike Leahy wrote:
> Hello list,
> I've been working on an application that uses Ka-Map, but I think I
> might consider adopting OpenLayers for the client-side part. I have
> been able to setup a map that loads two layers (see sample HTML below).
> When the map initially starts, I call roads.setVisibility(true);, and
> I see the roads layer overlaid on top of the aerial photography layer.
> It looks fine at that point...panning works fine. Once I zoom in or
> out, however, the base layer (the photography) does what is expected,
> but the roads layer just defaults to its original extent, and remains at
> the initial zoom level. Is there something I need to do to tie the
> roads layer to the zoom event?
> If this is a known issue, or if I'm just missing something, maybe
> someone can point me in the right direction. I'm using OpenLayers 2.6
> (should I try SVN?). The tile.php script is something that I have
> integrated into my application on the server - it's generally based on
> the one from kamap (checked out of svn about a month ago), but I don't
> think it's the source of this issue (i.e., if I make the roads layer the
> base layer on its own, it works fine).
> Thanks in advance for any help,
> Mike
> <html>
> <head>
> <script
> src="https://localhost/application/js/lib/OpenLayers.js"></script>
> </head>
> <body>
> var options = {
> maxExtent: new
> OpenLayers.Bounds(1327479,4883397,1415461,5034462),
> scales: [200000,150000,100000,75000,50000,25000,10000,5000],
> numZoomLevels: 8,
> tileSize: new OpenLayers.Size(400,300),
> units: "m"
> var aerials = new OpenLayers.Layer.KaMap("mymap",
> "https://localhost/application/tile.php",
> {layers:"0",i:"AGG_JPEG",map:"mymap",g:"Aerial
> Photography",sid:"somesessionid"}
> var roads = new OpenLayers.Layer.KaMap("mymap",
> {layers:"160",i:"alpha",map:"mymap",g:"Roads",sid:"somesessionid"},
> {numZoomLevels:8,scales:
> [200000,150000,100000,75000,50000,25000,10000,5000]}
> map.addLayers([aerials,roads]);
> OpenLayers.Bounds(1373558,4988812,1404038,5011460));
> </script>
> </body>
> </html>
