[OpenLayers-Users] Zooming with multiple kamap layers
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sat Jul 26 02:10:18 EDT 2008
Hello list,
I've been working on an application that uses Ka-Map, but I think I
might consider adopting OpenLayers for the client-side part. I have
been able to setup a map that loads two layers (see sample HTML below).
When the map initially starts, I call roads.setVisibility(true);, and
I see the roads layer overlaid on top of the aerial photography layer.
It looks fine at that point...panning works fine. Once I zoom in or
out, however, the base layer (the photography) does what is expected,
but the roads layer just defaults to its original extent, and remains at
the initial zoom level. Is there something I need to do to tie the
roads layer to the zoom event?
If this is a known issue, or if I'm just missing something, maybe
someone can point me in the right direction. I'm using OpenLayers 2.6
(should I try SVN?). The tile.php script is something that I have
integrated into my application on the server - it's generally based on
the one from kamap (checked out of svn about a month ago), but I don't
think it's the source of this issue (i.e., if I make the roads layer the
base layer on its own, it works fine).
Thanks in advance for any help,
Mike
<html>
<head>
<title>OpenLayers Example</title>
<script
src="https://localhost/application/js/lib/OpenLayers.js"></script>
</head>
<body>
<div style="width:100%; height:100%" id="map"></div>
<script defer="defer" type="text/javascript">
var options = {
maxExtent: new
OpenLayers.Bounds(1327479,4883397,1415461,5034462),
scales: [200000,150000,100000,75000,50000,25000,10000,5000],
numZoomLevels: 8,
tileSize: new OpenLayers.Size(400,300),
projection: "EPSG:4326",
units: "m"
var map = new OpenLayers.Map('map',options);
var aerials = new OpenLayers.Layer.KaMap("mymap",
"https://localhost/application/tile.php",
{layers:"0",i:"AGG_JPEG",map:"mymap",g:"Aerial
Photography",sid:"somesessionid"}
var roads = new OpenLayers.Layer.KaMap("mymap",
{layers:"160",i:"alpha",map:"mymap",g:"Roads",sid:"somesessionid"},
{numZoomLevels:8,scales:
[200000,150000,100000,75000,50000,25000,10000,5000]}
map.addLayers([aerials,roads]);
map.zoomToExtent(new
OpenLayers.Bounds(1373558,4988812,1404038,5011460));
</script>
</body>
</html>
