[OpenLayers-Users] OpenLayers.Control.TYPE_TOGGLE with DragFeature
Damien Dudognon ddudognon at anyware-tech.com
Mon Jun 2 12:40:36 EDT 2008
I want to use TYPE_TOGGLE to activate/desactivate draw and drag
controls. It works well with DrawFeature, but fails with DragFeature and
I don't understand why... Do you know how to solve this problem ?
var containerDraw = document.getElementById("panelDraw");
var drawpanel = new OpenLayers.Control.Panel({div: containerDraw});
c_point = new OpenLayers.Control.DrawFeature
    v_edit, OpenLayers.Handler.Point,
        type: OpenLayers.Control.TYPE_TOGGLE,
        'displayClass': 'olControlDrawFeaturePoint'
c_ligne = new OpenLayers.Control.DrawFeature
    v_edit, OpenLayers.Handler.Path,
        handlerOptions: {freehand: true},
        'displayClass': 'olControlDrawFeaturePath'
c_polygone = new OpenLayers.Control.DrawFeature
    v_edit, OpenLayers.Handler.Polygon,
        'displayClass': 'olControlDrawFeaturePolygon'
* In this case, TYPE_TOGGLE doesn't work
c_deplacement = new OpenLayers.Control.DragFeature
    v_edit, OpenLayers.Handler.Drag,
        'displayClass': 'olControlMoveItem'
drawpanel.addControls([c_point,c_ligne,c_polygone,c_deplacement]);
map.addControl(drawpanel);
Regards,
Damien
