[OpenLayers-Users] OpenLayers.Control.TYPE_TOGGLE with DragFeature
Eric Lemoine eric.c2c at gmail.com
Mon Jun 2 13:11:07 EDT 2008
On Mon, Jun 2, 2008 at 6:40 PM, Damien Dudognon
<ddudognon at anyware-tech.com> wrote:
> Hi,
> I want to use TYPE_TOGGLE to activate/desactivate draw and drag
> controls. It works well with DrawFeature, but fails with DragFeature and
> I don't understand why... Do you know how to solve this problem ?
> var containerDraw = document.getElementById("panelDraw");
> var drawpanel = new OpenLayers.Control.Panel({div: containerDraw});
> c_point = new OpenLayers.Control.DrawFeature
>    v_edit, OpenLayers.Handler.Point,
>        type: OpenLayers.Control.TYPE_TOGGLE,
>        'displayClass': 'olControlDrawFeaturePoint'
> c_ligne = new OpenLayers.Control.DrawFeature
>    v_edit, OpenLayers.Handler.Path,
>        handlerOptions: {freehand: true},
>        'displayClass': 'olControlDrawFeaturePath'
> c_polygone = new OpenLayers.Control.DrawFeature
>    v_edit, OpenLayers.Handler.Polygon,
>        'displayClass': 'olControlDrawFeaturePolygon'
> * In this case, TYPE_TOGGLE doesn't work
> c_deplacement = new OpenLayers.Control.DragFeature
>    v_edit, OpenLayers.Handler.Drag,
>        'displayClass': 'olControlMoveItem'
> drawpanel.addControls([c_point,c_ligne,c_polygone,c_deplacement]);
> map.addControl(drawpanel);
Probably because you don't have CSS for DragFeature, do you?
Eric
