[OpenLayers-Users] Using Openlayers.layer.text makes the map disappear
Eric Lemoine eric.c2c at gmail.com
Wed Jun 4 00:28:16 EDT 2008
On Tue, Jun 3, 2008 at 9:10 PM, PhilippeP <philippep62 at gmail.com> wrote:
> Hi,
> I'm trying to use openlayers and a dynamically created markers textfile.
> For the testing purpose I use a basic (only point coordonnates) static file
> : http://www.lessines.net/bizz_result_text_2007.txt , the map is on the
> following page : http://www.lessines.net/?page=9a .
> Hit in 'Recherche' in the right column, then the 'We're Open' picture to get
> to the map ...
> The map alone works perfectly, but when I try to link the textfile, the map
> stays blank ...
> Any ideas ??
> Is there a way to force Openlayers to display debugging error messages
> perhaps ??
> Thanks
> Philippe
Hi Philippe,
What's the projection system of your coords in the text file? Is it
also EPSG:41001?
Eric
