[OpenLayers-Users] GetFeatureInfo in a FrameCloud popup
Alessio Di Lorenzo alessio.dilorenzo at gmail.com
Mon Jun 9 17:16:03 EDT 2008
Thanks also to you! :)
I have not enough time to try your code suggestions in these days
(unexpected things to do...)
but I'll try to do some experiments as soon as possible
thx again, alessio
Obe, Regina ha scritto:
> I'm sure there is probably one around but don't seem to find it.  The
> Popup Matrix and Popup Mayhem examples provide sample use of FrameCloud
> among other popup types.
> Anyrate for FrameCloud() its pretty much like using any popup.
> Below is a snippet from one of my apps (this goes into your event
> handler function). Unfortunately can't give away more than this.
> Basically you declare a global variable popup at the top of your page.
> Where I have the innerhtmlgoeshere is where you would stuff the html you
> normally stuff in the div.innerHTML  (I think the rest of the code in
> the FeatureInfo stays pretty much the same)
>                 var tolerance = new OpenLayers.Pixel(6, 6);
>                 var min_px = new OpenLayers.Pixel(
>                                     e.xy.x - tolerance.x, e.xy.y +
> tolerance.y);
>                 var max_px = new OpenLayers.Pixel(
>                                     e.xy.x + tolerance.x, e.xy.y -
> tolerance.y);
>                 var min_ll = map.getLonLatFromPixel(min_px);
>                 var max_ll = map.getLonLatFromPixel(max_px);
>                    if (popup){
>                         popup.destroy();
>                         popup = null;
>                     popup = new OpenLayers.Popup.FramedCloud("property",
>                              new
> OpenLayers.LonLat(min_ll.lon,min_ll.lat),
>                              new OpenLayers.Size(400,500),
>                              innerhtmlgoeshere, null, true);
>                     map.addPopup(popup);
> Hope that helps,
> Regina
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> On Behalf Of Alessio Di Lorenzo
> Sent: Sunday, June 08, 2008 8:03 AM
> To: OpenLayers ML
> Subject: [OpenLayers-Users] GetFeatureInfo in a FrameCloud popup
> Hi list,
> I'd like to obtain the WMS GetFeatureInfo response in a framecloud popup
> instead in a separate frame/div (as displayed in the example at
> http://openlayers.org/dev/examples/example-list.html ).
> Is it possible? Are there any working examples that I can view?
> thaks in advance, alessio
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
