[OpenLayers-Users] How to use more than one 'SelectFeature' controls
hz20040 hz20040 at 126.com
Mon Jun 16 23:34:25 EDT 2008
Dear List!
I have got a problem about 'SelectFeature' control.
There are two gml layers.I want to use two 'SelectFeature' to select them.
But I found only the SelectFeature control which's gml layer is added last
will work.
In the code,if I use myMap.addLayers([gmlLayer1,gmlLayer2]),the gml2Control will
work well,but gml1Control will not work. If I use myMap.addLayers([gmlLayer2,gmlLayer1]), the gml1Control will work well,but gml2 not.
It looks like which gml layer is added last , the select control to it will work.
Can I use more then one 'SelectFeature' controls to more then one gml layers?
Thank you !
My code is:
        function init()
         myMap = new OpenLayers.Map('map3d');
            var opt= {numZoomLevels:1};
            var graphic = new OpenLayers.Layer.Image(
                                'name',
                                '/Images/Maps/chunxi.jpg',
                                //new OpenLayers.Bounds(-450, -289, 450, 289),
                                new OpenLayers.Bounds(-320, -240, 320, 240),
                                new OpenLayers.Size(1600, 1200),
                                opt);
            var userstyle =  OpenLayers.Util.extend({}, OpenLayers.Feature.Vector.style['userselect']);
            //add an image layer
            myMap.addLayers([graphic]);
           //one gml layer
            var gmlOption = {
                style:userstyle
            var gmlLayer1= new OpenLayers.Layer.GML("GML1", "url",gmlOption);
           //another gml layer
           var toolTipsOption = {
                //style:userstyle
           var gmlLayer2 = new OpenLayers.Layer.GML("GML2","url",toolTipsOption);
           myMap.addLayers([gmlLayer2,gmlLayer1]);
          // myMap.addLayers([gmlLayer1,gmlLayer2]);
            //one SelectFeature control:gml1Control
            gml1Control = new OpenLayers.Control.SelectFeature(gmlLayer1,
                {onSelect: onFeatureSelect,
                onUnselect:onFeatureUnselect,
                 hover:false
            myMap.addControl(gml1Control);
            gml1Control.activate();
           //another SelectFeature control:gml2Control
           gml2Control = new OpenLayers.Control.SelectFeature(gmlLayer2,
                    onSelect:onToolTipsFeatureSelect,
                    onUnselect:onToolTipsFeatureUnselect,
                    hover:false
           myMap.addControl(gml2Control );
           gml2Control.activate();
           myMap.setCenter(new OpenLayers.LonLat(0, 0), 1);
           myMap.zoomToMaxExtent();
    function onToolTipsFeatureSelect(feature)
        alert("onToolTipsFeatureSelect");
    function onToolTipsFeatureUnselect(feature)
        alert("onToolTipsFeatureUnselect");
    function onFeatureSelect(feature)
        alert("onFeatureSelect");
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080617/0779b7e0/attachment.html
