[OpenLayers-Users] Cannot upgrade to 2.6 because of vector lines disappearing in IE (Frustrated)
Andreas Hocevar andreas.hocevar at gmail.com
Wed Jun 18 03:47:48 EDT 2008
Linda,
it would be easier to help you if you provide a more stripped down
example that reproduces your problem.
Regards,
Andreas.
On Mon, Jun 16, 2008 at 6:13 AM, Linda Rawson <linda.rawson at gmail.com> wrote:
> Any 2.6 vector author's out there?  I still have this issue.
> Thanks,
> Linda
> On Sun, Jun 8, 2008 at 3:07 PM, Linda Rawson <linda.rawson at gmail.com> wrote:
>> No.  With 2.5 you see the lines at all zoom levels in both IE and
>> Firefox.  This must be a problem in Firefox as well.  Maybe that will
>> help you guys trouble shoot.
>> Linda
>> On Sun, Jun 8, 2008 at 2:11 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> > On Wed, Jun 4, 2008 at 7:24 PM, Linda Rawson <linda.rawson at gmail.com>
>> > wrote:
>> >> I have a problem with upgrading to 2.6.  I need some of the other
>> >> features and I cannot get this to work.  I have tried to find out
>> >> where in the code it has changed but I cannot find it.
>> >> ONLY in IE does this not work.
>> >> Extract this example.  You will see a green line and an aqua marker on
>> >> the screen.
>> >> Push the button that says Zoom 5.
>> >> You still have a green line and an aqua marker on the screen.
>> >> Push the button that says Zoom 6.
>> >> No lines.  Not for Zoom 7 or Zoom 8 either.
>> > With FF2 I see the line after Zoom 6, but its coords seem to have
>> > changed. I don't see line after Zoom 7 and 8. Is this expected?
>> > Eric
>> Linda Rawson
> Linda Rawson
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
