[OpenLayers-Users] Cannot upgrade to 2.6 because of vector lines disappearing in IE (Frustrated)
Linda Rawson linda.rawson at gmail.com
Wed Jun 18 10:48:33 EDT 2008
Absolutely.  Anything to help me here!  I so want to go the new
version.  In this example, if I remove the first line I add then all
of the zoom buttons work perfectly.  The line appears at all zoom
levels.  The minute I add more than one line the problem occurs.  I
had all the style sheet stuff in the first example because I noticed
you changed from relative positioning to absolute so I thought maybe
that was causing the problem but that is not the case.  It looks
complex but all I am doing is adding 2 lines and a marker to a
spherical mercator projection map.  This works in 2.5 just not in 2.6.
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Linda Rawson Test Case</title><link
href="http://www.openlayers.org/api/theme/default/style.css"
rel="stylesheet" type="text/css">
<style>
	#map {
	      width: 720px;
	      height: 720px;
	      border: 1px solid #4B3624;
	      background: White;
	.olControlAttribution { bottom: 0px!important }
</style>
<script src="http://www.openlayers.org/api/OpenLayers.js"
type="text/javascript"></script>
<script src='http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
<script type="text/javascript">var map;
      // avoid pink tiles
      OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
      OpenLayers.Util.onImageLoadErrorColor = "transparent";
       var vectorLayer;
       var markerLayer, boxes, newPoint;
       function init(){
               var options = {
                   projection: new OpenLayers.Projection("EPSG:900913"),
                   //displayProjection: new OpenLayers.Projection("EPSG:4326"),
                   units: "m",
                       numZoomLevels: 19,
                   maxResolution: 156543.0339,
                   maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
                                                    20037508, 20037508.34)
               map = new OpenLayers.Map('map', options);
               // create Google Mercator layers
               var gmap = new OpenLayers.Layer.Google(
                   "Google Streets",
                   {'sphericalMercator': true}
               map.addLayer(gmap);
               map.addControl(new OpenLayers.Control.PanZoomBar());
               map.addControl(new OpenLayers.Control.MousePosition());
               vectorLayer = new OpenLayers.Layer.Vector("Trails");
               markerLayer = new OpenLayers.Layer.Markers("WayPoints");
               map.addLayers([vectorLayer,markerLayer]);
               var style_trail = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default']);
               style_trail.strokeColor = "green";
               style_trail.strokeWidth = 5;
               var pointList = [];
               newPoint = new
OpenLayers.Geometry.Point(-13653735.8487833,5726045.3578081);
               pointList.push(newPoint);
               newPoint = new
OpenLayers.Geometry.Point(-13653731.3960036,5726056.5070679);
               newPoint = new
OpenLayers.Geometry.Point(-13653730.8394062,5726044.7207079);
               newPoint = new
OpenLayers.Geometry.Point(-13653743.1958697,5726043.9243328);
               newPoint = new
OpenLayers.Geometry.Point(-13653754.1051798,5726046.9505586);
               newPoint = new
OpenLayers.Geometry.Point(-13653760.4503907,5726056.5070679);
               newPoint = new
OpenLayers.Geometry.Point(-13653767.4635187,5726065.5857612);
               newPoint = new
OpenLayers.Geometry.Point(-13653830.136392,5726052.2066375);
               newPoint = new
OpenLayers.Geometry.Point(-13653846.5003571,5726042.3315828);
               var lineFeature = new OpenLayers.Feature.Vector(
                       new OpenLayers.Geometry.LineString(pointList));
               lineFeature.fid = 52730;
               vectorLayer.addFeatures(lineFeature);
               newPoint = new
OpenLayers.Geometry.Point(-12250153.3626406,4852001.6114048);
               newPoint = new
OpenLayers.Geometry.Point(-12194315.5060664,4800503.5113048);
               newPoint = new
OpenLayers.Geometry.Point(-12180445.0975155,4873109.008858);
                            new
OpenLayers.Geometry.LineString(pointList),null,style_trail);
               lineFeature.fid = 52751;
               vectorLayer.addFeatures([lineFeature]);
               var size = new OpenLayers.Size(15, 15);
               var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
               var icon = new
OpenLayers.Icon('http://boston.openguides.org/markers/AQUA.png', size,
offset);
               markerLayer.addMarker(new OpenLayers.Marker(new
OpenLayers.LonLat((newPoint.x + 400), (newPoint.y - 400)), icon));
               map.setCenter(new OpenLayers.LonLat(newPoint.x, newPoint.y), 13)
       function zoomToScale(zoom) {
          if (zoom == 8) map.zoomToScale(3385.5001275);
          else if(zoom == 7) map.zoomToScale(6771.000255);
          else if (zoom == 6) map.zoomToScale(13542);
          else if (zoom == 5) map.zoomToScale(27084.001020);
          else if (zoom == 4) map.zoomToScale(54168.001020);
          else if (zoom == 3) map.zoomToScale(108337);
          else if (zoom == 2) map.zoomToScale(3466752.1306573446);
          else if (zoom == 1) map.zoomToScale(13867008.522629378);
          else if (zoom == 0) map.zoomToScale(55468034.09051751);
</script>
</head>
<body onLoad="init()">
<h1 id="title">Linda's Example.  Push Zoom 5.  You see lines.  Push
Zoom 6.  No lines.</h1>
     <div id="map">
     </div>
     <button onClick="zoomToScale(5);">Zoom 5</button>
     <button onClick="zoomToScale(6);">Zoom 6</button>
     <button onClick="zoomToScale(7);">Zoom 7</button>
     <button onClick="zoomToScale(8);">Zoom 8</button>
</body>
</html>
On Wed, Jun 18, 2008 at 1:47 AM, Andreas Hocevar
<andreas.hocevar at gmail.com> wrote:
> Linda,
> it would be easier to help you if you provide a more stripped down
> example that reproduces your problem.
> Regards,
> Andreas.
> On Mon, Jun 16, 2008 at 6:13 AM, Linda Rawson <linda.rawson at gmail.com> wrote:
> > Any 2.6 vector author's out there?  I still have this issue.
> > Thanks,
> > Linda
> > On Sun, Jun 8, 2008 at 3:07 PM, Linda Rawson <linda.rawson at gmail.com> wrote:
> >> No.  With 2.5 you see the lines at all zoom levels in both IE and
> >> Firefox.  This must be a problem in Firefox as well.  Maybe that will
> >> help you guys trouble shoot.
> >> Linda
> >> On Sun, Jun 8, 2008 at 2:11 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> >> > On Wed, Jun 4, 2008 at 7:24 PM, Linda Rawson <linda.rawson at gmail.com>
> >> > wrote:
> >> >> I have a problem with upgrading to 2.6.  I need some of the other
> >> >> features and I cannot get this to work.  I have tried to find out
> >> >> where in the code it has changed but I cannot find it.
> >> >> ONLY in IE does this not work.
> >> >> Extract this example.  You will see a green line and an aqua marker on
> >> >> the screen.
> >> >> Push the button that says Zoom 5.
> >> >> You still have a green line and an aqua marker on the screen.
> >> >> Push the button that says Zoom 6.
> >> >> No lines.  Not for Zoom 7 or Zoom 8 either.
> >> > With FF2 I see the line after Zoom 6, but its coords seem to have
> >> > changed. I don't see line after Zoom 7 and 8. Is this expected?
> >> > Eric
> >> Linda Rawson
> > Linda Rawson
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
Linda Rawson
