[OpenLayers-Users]  Newbie Projection Troubles
    bmcbride
    bmcbride at cha-llp.com
    Wed Jun 18 17:44:42 EDT 2008
Hello,
I'm working with the spherical-mercator example and trying to add a WMS
layer, which is in EPSG:4326.  The WMS (NYC Imagery) layer will not render
on the map and I'm sure it has to do with either projection, maxResolution,
or maxExtent variables, but I cannot figure it out.  Any help would be
greatly appreciated.  The code is below:
// make map available for easy debugging
        var map;
        // avoid pink tiles
        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
        OpenLayers.Util.onImageLoadErrorColor = "transparent";
        function init(){
            var options = {
                projection: new OpenLayers.Projection("EPSG:900913"),
                displayProjection: new OpenLayers.Projection("EPSG:4326"),
                units: "m",
                maxResolution: 156543.0339,
                maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
                                                 20037508, 20037508.34)
            map = new OpenLayers.Map('map', options);
            // create Google Mercator layers
            var gmap = new OpenLayers.Layer.Google(
                "Google Streets",
                {'sphericalMercator': true}
            var gsat = new OpenLayers.Layer.Google(
                "Google Satellite",
                {type: G_SATELLITE_MAP, 'sphericalMercator': true}
            var ghyb = new OpenLayers.Layer.Google(
                "Google Hybrid",
                {type: G_HYBRID_MAP, 'sphericalMercator': true}
            // create Virtual Earth layers
            var veroad = new OpenLayers.Layer.VirtualEarth(
                "Virtual Earth Roads",
                {'type': VEMapStyle.Road, 'sphericalMercator': true}
            var veaer = new OpenLayers.Layer.VirtualEarth(
                "Virtual Earth Aerial",
                {'type': VEMapStyle.Aerial, 'sphericalMercator': true}
            var vehyb = new OpenLayers.Layer.VirtualEarth(
                "Virtual Earth Hybrid",
                {'type': VEMapStyle.Hybrid, 'sphericalMercator': true}
            // create Yahoo layer
            var yahoo = new OpenLayers.Layer.Yahoo(
                "Yahoo Street",
            var yahoosat = new OpenLayers.Layer.Yahoo(
                "Yahoo Satellite",
                {'type': YAHOO_MAP_SAT, 'sphericalMercator': true}
            var yahoohyb = new OpenLayers.Layer.Yahoo(
                "Yahoo Hybrid",
                {'type': YAHOO_MAP_HYB, 'sphericalMercator': true}
            // create OSM layer
            var mapnik = new OpenLayers.Layer.TMS(
                "OpenStreetMap (Mapnik)",
                "http://tile.openstreetmap.org/",
                    type: 'png', getURL: osm_getTileURL,
                    displayOutsideMaxExtent: true,
                    attribution: ' http://www.openstreetmap.org/
OpenStreetMap '
            // create OSM layer
            var osmarender = new OpenLayers.Layer.TMS(
                "OpenStreetMap (Tiles at Home)",
                "http://tah.openstreetmap.org/Tiles/tile.php/",
OpenStreetMap '
            // create WMS layer
            var wms = new OpenLayers.Layer.WMS(
                "World Map",
                "http://world.freemap.in/tiles/",
                {'layers': 'factbook-overlay', 'format':'png'},
                    'opacity': 0.4,
                    'isBaseLayer': false,'wrapDateLine': true
			var nysdop = new OpenLayers.Layer.WMS(
                "NYSDOP",
"http://imsortho.cr.usgs.gov/servlet/com.esri.wms.Esrimap/USGS_EDC_Ortho_NYSDOP_Grid?",
                {'layers': "NY_NYC_2006_2FT_NC"},{projection:"EPSG:4326"}
            // create a vector layer for drawing
            var vector = new OpenLayers.Layer.Vector("Editable Vectors");
            map.addLayers([gmap, gsat, ghyb, nysdop, veroad, veaer, vehyb,
                           yahoo, yahoosat, yahoohyb, mapnik, osmarender,
                           wms, vector]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.addControl(new OpenLayers.Control.EditingToolbar(vector));
            map.addControl(new OpenLayers.Control.Permalink());
            map.addControl(new OpenLayers.Control.MousePosition());
            if (!map.getCenter()) {map.zoomToMaxExtent()}
        function osm_getTileURL(bounds) {
            var res = this.map.getResolution();
            var x = Math.round((bounds.left - this.maxExtent.left) / (res *
this.tileSize.w));
            var y = Math.round((this.maxExtent.top - bounds.top) / (res *
this.tileSize.h));
            var z = this.map.getZoom();
            var limit = Math.pow(2, z);
            if (y < 0 || y >= limit) {
                return OpenLayers.Util.getImagesLocation() + "404.png";
            } else {
                x = ((x % limit) + limit) % limit;
                return this.url + z + "/" + x + "/" + y + "." + this.type;
The following example works fine, but I need the commercial imagery and OSM
mapnik data available...
var map = null;
        function init(){
            map = new OpenLayers.Map('map');
            var ol_wms = new OpenLayers.Layer.WMS(
                "OpenLayers WMS",
                "http://labs.metacarta.com/wms/vmap0",
                {layers: 'basic'}
                "NYSDOP",
                {layers: "NY_NYC_2006_2FT_NC"}
            map.addLayers([ol_wms, nysdop]);
            map.zoomToMaxExtent();
View this message in context: http://www.nabble.com/Newbie-Projection-Troubles-tp17157211p17157211.html
