[OpenLayers-Users] Dynamically change a control handler
Pierre GIRAUD bluecarto at gmail.com
Thu Jun 19 05:07:31 EDT 2008
I had a quick test with your code snippets and this worked well with a
custom drawFeature control.
My feeling is that the code you provided is not responsible for the
issue encountered on IE.
Regards,
Pierre
Here's my code (tested in IE6 and IE7) :
<html xmlns="http://www.w3.org/1999/xhtml">
    <head>
        <title>Draw Feature Example</title>
        <link rel="stylesheet" href="../theme/default/style.css"
type="text/css" />
        <link rel="stylesheet" href="style.css" type="text/css" />
        <style type="text/css">
            #controlToggle li, #handlerToggle li  {
                list-style: none;
            p {
                width: 512px;
        </style>
        <script src="../lib/OpenLayers.js"></script>
        <script type="text/javascript">
            var map, drawControl;
            OpenLayers.Util.onImageLoadErrorColor = "transparent";
            function init(){
                map = new OpenLayers.Map('map');
                var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
                    "http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
                var pointLayer = new OpenLayers.Layer.Vector("Point Layer");
                var lineLayer = new OpenLayers.Layer.Vector("Line Layer");
                var polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer");
                map.addLayers([wmsLayer, pointLayer, lineLayer, polygonLayer]);
                map.addControl(new OpenLayers.Control.LayerSwitcher());
                map.addControl(new OpenLayers.Control.MousePosition());
                drawControl = new
OpenLayers.Control.DrawFeatureCustom(pointLayer,
                                OpenLayers.Handler.Point);
                map.addControl(drawControl);
                map.setCenter(new OpenLayers.LonLat(0, 0), 3);
                document.getElementById('noneToggle').checked = true;
                document.getElementById('pointToggle').checked = true;
            function toggleControl(element) {
                if(element.value == 'draw' && element.checked) {
                    drawControl.activate();
                    drawControl.setHandlerType('POINT');
                } else {
                    drawControl.deactivate();
            function toggleHandler(element) {
                drawControl.setHandlerType(element.value);
 * Class: OpenLayers.Control.DrawFeatureCustom
 * Draws features on a vector layer when active.
 * Inherits from:
 *  - <OpenLayers.Control>
OpenLayers.Control.DrawFeatureCustom =
OpenLayers.Class(OpenLayers.Control.DrawFeature, {
    initialize: function(layer, handler, options) {
        OpenLayers.Control.DrawFeature.prototype.initialize.apply(this,
[layer, handler, options]);
    draw: function() {
        switch (this.handlerType) {
            case 'POINT':
                this.handler = new OpenLayers.Handler.Point(
                   this,
                   {done: this.selectGeom},
                   {keyMask: this.keyMask}
                break;
            case 'BOX':
                this.handler = new OpenLayers.Handler.RegularPolygon(
                   this,
                   {keyMask: this.keyMask, sides: 4, irregular: true}
                break;
    setHandlerType: function(handlerType) {
        this.handlerType = handlerType;
        if (this.active) {
            this.deactivate();
            this.draw();
            this.activate();
        </script>
    </head>
    <body onload="init()">
        <h1 id="title">OpenLayers Draw Feature Example</h1>
        <div id="tags"></div>
        <p id="shortdesc">
            Demonstrate on-screen digitizing tools for point, line,
and polygon creation.
        </p>
        <div id="map" class="smallmap"></div>
        <ul id="controlToggle">Controls
            <li>
                <input type="radio" name="type" value="none" id="noneToggle"
                       onclick="toggleControl(this);" checked="checked" />
                <label for="noneToggle">navigate</label>
            </li>
            <li>
                <input type="radio" name="type" value="draw"
id="drawToggle" onclick="toggleControl(this);" />
                <label for="drawToggle">draw</label>
            </li>
        </ul>
        <ul id="toggleHandler">Draw Handlers
            <li>
                <input type="radio" name="handler" value="POINT"
id="pointToggle"
                       onclick="toggleHandler(this);" checked="checked" />
                <label for="pointToggle">point</label>
            </li>
            <li>
                <input type="radio" name="handler" value="BOX"
id="polygonToggle" onclick="toggleHandler(this);" />
                <label for="polygonToggle">polygon</label>
            </li>
        </ul>
        </div>
    </body>
</html>
On Wed, Jun 18, 2008 at 1:43 PM, Gilles Bassière
<gilles.bassiere at makina-corpus.com> wrote:
> Hi list,
> I'd like to know if there is a cross-browser way to change the mouse handler
> associated to a control.
> Context: I want to query the server for a given area. This area may be a
> point, a box or a any polygon. The user can choose the type of area with
> simple html radiobuttons.
> My control is set up with the following draw() method:
> draw: function() {
>      case 'POINT':
>            this,
>         break;
>      case 'BOX':
>            this,
>         break;
> I added a custom method in order to set the "handlerType" property:
>   if (this.active) {
>      this.deactivate();
>      this.draw();
>      this.activate();
> All this works pretty fine in Firefox but does not in IE...
> The behavior in IE is the following:
> - when the control is selected, the default point handler works fine and the
> user can click on the map to fire a data request.
> - if the user change the handler type (using html radiobuttons and so, the
> control setHandlerType method), the mouse handler is lost until the first
> click on the map.
> Right after the call to setHandlerType(), I expect is to see my new handler
> but in IE, there is just no handler. The user needs to click once on the map
> and then the handler appears...
> Is it simply possible to achieve dynamic replacement of a control handler?
> If so, can anyone point me in the right direction?
> Regards
> Gilles
> Gilles Bassiere
> MAKINA CORPUS
> 30 rue des Jeuneurs
> FR-75002 PARIS
> +33 (0) 1 44 82 00 80
> http://www.makina-corpus.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
