[OpenLayers-Users] How to use the SelectFeature Control's select method without triggering onSelect
Eric Lemoine eric.c2c at gmail.com
Fri Jun 20 01:34:23 EDT 2008
Hi. What call do you use to select the feature when a list element is
selected? I think using layer.drawFeature(feature, 'select') should do
the trick. Cheers. Eric
2008/6/19, dukie <myjiang at yahoo.com>:
> I am relatively new to OpenLayers, and having fun with it.
> I run into an issue that I am sure someone here may have already run into.
> I am trying to set up 2-way communication between a vector layer and a query
> results list.
> What happens is that hovering over a feature (hover:true) or click on a
> feature, the onSelect
> event is triggered, which enables me to triggers a select (highlight) on a
> row in my feature list.
> Selecting multiple features (using clicks) allows me to select multiple rows
> in my list.
> Now I want to get the reverse done.  When selecting rows from my feature
> list, I want the
> corresponding features to become selected.  The problem is that every time a
> feature
> become selected, it triggers its onSelect AGAIN,   interfering with what I
> am doing on the list.
> Is there a way to use the SelectFeature's select method from code without
> triggering the onSelect
> event ?
> Thanks in Advance.
> http://www.nabble.com/How-to-use-the-SelectFeature-Control%27s-select-method-without-triggering-onSelect-tp17983515p17983515.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
