[OpenLayers-Users] FramedCloud and autoSize
Matthew Atkins Matthew.Atkins at loyola.com
Fri Jun 20 10:34:38 EDT 2008
Wendell,
As Chris mentioned the patch to ticket 1570 is not the entire solution.
You will need to watch out for how you are defining your CSS with the
FramedCloud content. The getRenderedDimensions() function creates a new
DIV off-screen in order to calculate the size of the HTML content
dynamically but it does not inherit the CSS rules like
".olFramedCloudPopupContent" and it is not inserted at the same level in
the DOM hierarchy (it's appended to the document's BODY).
So if you write CSS for your popup's content with selectors like:
.olFramedCloudPopupContent h2 { /* rules */ }
.olFramedCloudPopupContent table { /* rules */ }
.olFramedCloudPopupContent p { /* rules */ }
The styles will be applied to the content when it shows within the popup
on-screen but the calculated size will be incorrect because the CSS
rules were not applied (do not match) off-screen.
Wally Atkins
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Wendell Turner
Sent: Friday, June 20, 2008 9:01 AM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] FramedCloud and autoSize
On Thu, Jun 19, 2008 at 11:19:58PM -0400, Christopher Schmidt wrote:
> On Thu, Jun 19, 2008 at 09:42:24PM -0500, Erik Uzureau wrote:
> > Dear Wendell,
> > There is a bug in the getRenderedDimensions() function which was
> > found, reported, and fixed by a superstar member from the community,
> > one Wally somethingerother.
> > The fix is here:
> > http://trac.openlayers.org/ticket/1570
> > ... and in trunk as well. Hopefully that will help getting those
sizes
> > fixed up right.
> I actually sort of doubt that this is the entire solution. One problem
> is that paddings (or maybe it's margins) on elements aren't
neccesarily
> included in the calculations of scrollWidth.
> I typically do something like:
>   .olPopupContent h2 { margin: 0px; padding: 0px; }
> to minimize the padding around my headers so that they don't get
> included.
> -- Chris
> > Let us know if it works,
Yes, the patch works great!  Thanks to Wally Atkins and the
rest.  I'll also try the margin padding, that should help.
Wendell
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
