[OpenLayers-Users] Draw features one by one in IE?
Eric Lemoine eric.c2c at gmail.com
Mon Jun 23 09:41:30 EDT 2008
On Mon, Jun 23, 2008 at 3:34 PM, realjax <jax at schildmos.nl> wrote:
> realjax wrote:
>> No unfortunately. I measured the addfeatures method to be the bottleneck
>> here. It receives an array with features and then the delay starts..
>> I did a test with 800 objects.  That took IE over 200,000 ms, while
>> Firefox was done in 4000...
>> Anyway, looks like I need to do some more research..
>> Thanks for your help sofar!
> Small update:
> Changed a few things around in OL and that took the 200.000ms addFeatures
> took in IE down to 10.000ms.
Great!
> Not bad, but the problem remains. IE still needs an incredible amount of
> time to render the vectors..
You mean 10.000ms is still unacceptable compared to the 4.000ms FF takes?
> The change also improved performance in firefox by 40 to 50 percent by the
> way..
> I will post the changes asap.
I'm eager to see your changes.
Thanks,
Eric
