[OpenLayers-Users] Draw features one by one in IE?
Kusum kusum at infobase.in
Tue Jun 24 00:47:46 EDT 2008
I am eager too as this had taken a lot of time of mine also.......
Cheers
kusum
Sent: Monday, June 23, 2008 7:11 PM
To: "realjax" <jax at schildmos.nl>
Cc: <users at openlayers.org>
Subject: Re: [OpenLayers-Users] Draw features one by one in IE?
> On Mon, Jun 23, 2008 at 3:34 PM, realjax <jax at schildmos.nl> wrote:
>> realjax wrote:
>>> No unfortunately. I measured the addfeatures method to be the bottleneck
>>> here. It receives an array with features and then the delay starts..
>>> I did a test with 800 objects.  That took IE over 200,000 ms, while
>>> Firefox was done in 4000...
>>> Anyway, looks like I need to do some more research..
>>> Thanks for your help sofar!
>> Small update:
>> Changed a few things around in OL and that took the 200.000ms addFeatures
>> took in IE down to 10.000ms.
> Great!
>> Not bad, but the problem remains. IE still needs an incredible amount of
>> time to render the vectors..
> You mean 10.000ms is still unacceptable compared to the 4.000ms FF takes?
>> The change also improved performance in firefox by 40 to 50 percent by
>> the
>> way..
>> I will post the changes asap.
> I'm eager to see your changes.
> Thanks,
> Eric
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
