[OpenLayers-Users] link with gps
Didrik Pinte lists at dipole-consulting.com
Thu Jun 26 09:55:33 EDT 2008
On Thu, 2008-06-26 at 15:45 +0200, Kenneth Skovhede, GEOGRAF A/S wrote:
> Its fairly easy.
> These are the steps:
> 1. Set up OL map (I assume you have this)
> 2. Read data from GPS
> 3. call map.setCenter with the GPS data
> Step 2 varies, depending on the GPS brand.
> Usually you can tweak the device to put out NMEA compliant data on a
> COM port.
> NMEA is human readable, and specs can be found online.
> Step 3 may cause trouble, because you have to interact with a
> javascript inside a page.
> On way is to simply host the page in an application, ie. a .Net form,
> then the access is there.
> Another way is to create a webservice / micro webserver that returns
> the current position.
> A javascript inside the page can then poll the position (via AJAX),
> and update the center.
> You may run into trouble if your map is projected into something thats
> not Lat/Lon compatible.
> In that case, take a look at the Proj.4 library, avalible for both
> javascript and regular programming.
> Regards, Kenneth Skovhede, GEOGRAF A/S
Hi Kenneth,
Thank you for your answer.
I have just found some things for the step 2 :
- Garmin seem to provide a closed source plugin with an open source
javascript library that allows to communicate easily with the gps
- another closed source application called gpsgate that can interface
with a lot of gps and expose kind of webserver to it's javascript api.
Nothing fully opensource for the moment ;-) There is some potential for
a new projet.
Best regards,
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080626/f9f0050b/attachment.bin
