[OpenLayers-Users] GeoRSS and Custom Icons
Eric Lemoine eric.c2c at gmail.com
Sun Jun 29 09:54:48 EDT 2008
Current HTTP Protocol does CRUD through HTTP POST, GET, PUT, DELETE.
It should be generic enough for implementing Protocol.FeatureServer
and Protocol.OSM based upon it. So if we keep it as-is i tend to think
we should rename it REST. However i like your idea of having a simple
read-only, HTTP GET-based Protocol that other network Protocols will
use internally. Thanks. Eric
2008/6/29, Christopher Schmidt <crschmidt at metacarta.com>:
> On Sun, Jun 29, 2008 at 11:34:23AM +0200, Eric Lemoine wrote:
>> Hi. Regarding Protocol.HTTP maybe the naming isn't really appropriate
>> since any OL network protocol is HTTP-based.
> The Google Gears protocol is HTTP based? :)
>> Since Protocol.HTTP uses
>> GET, POST, PUT, DELETE, Protocol.REST might be a better name.
> That depends what we put in the HTTP protocol. My assumption was that
> something like OSM and something like FeatureServer could both be based
> on subclasses of the HTTP Protocol -- that the HTTP Protocol wouldn't
> actually embed any write information, only reading from bounding boxes.
> If the plan is to have the HTTP Protocol do more than that, then yes,
> perhaps REST makes sense, but I think there is still a class of
> HTTP-centric, non-SimpleFeatures REST that could be usefully subclassed
> from a smaller protocol.
> -- Chris
>> 2008/6/25, Christopher Schmidt <crschmidt at metacarta.com>:
>> > On Wed, Jun 25, 2008 at 03:53:33PM +0200, Eric Lemoine wrote:
>> >> On Wed, Jun 25, 2008 at 3:09 PM, Christopher Schmidt
>> >> <crschmidt at metacarta.com> wrote:
>> >> > On Wed, Jun 25, 2008 at 01:54:42PM +0200, Eric Lemoine wrote:
>> >> >> Although i find it weird to use a GML layer with a format different
>> >> >> than GML i agree that it's good to avoid code at the application
>> >> >> level. Thanks Andreas. Eric
>> >> > As Andreas pointed out, this is a flaw in naming. This is simply for
>> >> > 'historical reasons' -- It was named that way early on, before I
>> >> > really
>> >> > knew what I was doing. (It was named, for example, before we had
>> >> > formats, back when it really *was* about GML.)
>> >> > The GML and WFS layers can essentially be thought of two different
>> >> > strategies: GML is a Layer which uses a "Fixed" strategy, and WFS is
>> >> > a
>> >> > Layer which uses a "BBOX" strategy.
>> >> > Both of them are tied to the HTTP Protocol.
>> >> The WFS layer is tied to the "WFS" protocol.
>> > More so than the HTTP protocol, I'll admit; but the entire reason for
>> > the vector behavior work is just that the protocol stuff really isn't
>> > well encapsulated, so we'll just put it this way: "The WFS layer is a
>> > fscking mess" :)
>> >> > It's unfortunate that they're named this way, but that's one of the
>> >> > things that the vector behavior work is changing: once we've
>> >> > refactored
>> >> > things, we can start creating layers that actually make sense for
>> >> > their
>> >> > names :)
>> >> Ok, but what will we do with the WFS and GML layers? Will we keep them
>> >> with the same names and behaviors to maintain backward compatibility?
>> > I don't know exactly what we'll do: if we can change the underlying
>> > implementation of these to just be simple wrappers around a vector layer
>> > without changing API-supported behavior, that would be preferable:
>> > otherwise, we may have to maintain the existing code. For example, the
>> > WFS layer has support to render with Markers, something that the vector
>> > behavior changes won't give us, so we can't really just dump the
>> > Layer.WFS code that does that and depend on the vector behavior instead.
>> > Regards,
>> > Christopher Schmidt
>> > MetaCarta
> Christopher Schmidt
> MetaCarta
