[OpenLayers-Users] Mouseposition div
Andy Dale
andy.dale at gmail.com
Tue Mar 11 09:17:21 EDT 2008
Hi Steven,
Thanks for the help, it now works :-)
Cheers,
Andy
On 11/03/2008, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Andy Dale wrote:
> > Hi,
> > I have an extracted all the javascript that is used for displaying the
> > map into a separate .js file. This works very well, the only problem
> > being that, I cannot figure out how to set the mouseposition control to
> > be in a separate div. I initialize the control like so:
> > map.addControl(new OpenLayers.Control.MousePosition({element:
> $('mydiv')}));
> > where mydiv will exist on every page i use the map on. As an experiment
> > i include all the JavaScript contained within the external javascript in
> > head section, and the MousePosition is displayed in the correct div.
> > Is there a way to set the div for the mouse position if you are
> > including the javascript to display the map as an external file ??
> Andy,
> Create an initialize function that executes your map initialization and
> put the in your external file. Then
> <body onLoad=myInitialize()>
> The problem you are having in that 'mydiv' has not been created in the
> DOM yet when you execute the map.addControl... command above, but it
> will be when the onLoad event is fired.
> -Steve W
> http://imaptools.com/
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080311/c0807673/attachment.html
