[OpenLayers-Users] php postgis query - incompete geometry returned??
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Wed Mar 19 14:51:05 EDT 2008
I don't think this is the right list for this question, did you post to
the wrong list?
Best regards,
Bart
Edel Banks wrote:
> Hi All,
> I've have a problem with querying a postgis table from php. When I run
> the query in pgadmin I get one geometry result (correct one) and when
> I run it in php the geometry gets shortened somehow? I've tested the
> pgadmin result in openjump and the route is correct.
> I'm trying to get the wkt of the geom so I can draw it on a openlayers
> map, similar to the pgrouting tutorial.
> Run the query in pgadmin:
> Query:
> SELECT gid, source, target, astext(the_geom) from required_roads_edge
> where gid IN
> (SELECT edge_id FROM shortest_path('
> SELECT gid as id, source::integer, target::integer,
> length::double precision as cost FROM required_roads',
> 568, 600, false, false))
> PGADMIN Result: (sorry I know it's untidy)
> GID, Source, Target, Geom AsText
> 761;6780;8203;"MULTILINESTRING
> ((304782.351 234010.52,304784.841 234022.038))"
> 760;6677;8203;"MULTILINESTRING((304779.648 234057.624,304779.251
> 234053.092,304779.236 234052.959,304779.222 234052.826,304779.208
> 234052.693,304779.195 234052.559,304779.181 234052.426,304779.168
> 234052.293,304779.155 234052.159,304779.143 234052.025,304779.13
> 234051.893,304779.118 234051.76,304779.106 234051.626,304779.095
> 234051.493,304779.084 234051.36,304779.073 234051.226,304779.062
> 234051.093,304779.052 234050.959,304779.042 234050.826,304779.032
> 234050.692,304779.022 234050.559,304779.013 234050.425,304779.004
> 234050.292,304778.995 234050.158,304778.987 234050.024,304778.979
> 234049.891,304778.971 234049.757,304778.963 234049.623,304778.956
> 234049.49,304778.949 234049.356,304778.942 234049.222,304778.935
> 234049.089,304778.929 234048.955,304778.923 234048.821,304778.917
> 234048.687,304778.912 234048.554,304778.907 234048.42,304778.902
> 234048.286,304778.897 234048.152,304778.893 234048.018,304778.889
> 234047.885,304778.885 234047.751,304778.882 234047.617,304778.879
> 234047.482,304778.876 234047.348,304778.873 234047.215,304778.871
> 234047.082,304778.869 234046.948,304778.867 234046.814,304778.865
> 234046.68,304778.864 234046.546,304778.863 234046.412,304778.863
> 234046.278,304778.862 234046.144,304778.862 234046.011,304778.862
> 234045.877,304778.863 234045.743,304778.863 234045.609,304778.864
> 234045.475,304778.865 234045.341,304778.867 234045.207,304778.869
> 234045.073,304778.871 234044.94,304778.873 234044.806,304778.876
> 234044.672,304778.879 234044.538,304778.882 234044.404,304778.885
> 234044.27,304778.889 234044.136,304778.893 234044.003,304778.902
> 234043.735,304778.95 234043.561,304778.998 234043.388,304779.047
> 234043.215,304779.095 234043.041,304779.145 234042.868,304779.193
> 234042.695,304779.242 234042.521,304779.291 234042.348,304779.34
> 234042.175,304779.39 234042.002,304779.439 234041.829,304779.489
> 234041.655,304779.539 234041.482,304779.589 234041.309,304779.639
> 234041.136,304779.689 234040.963,304779.739 234040.791,304779.79
> 234040.618,304779.84 234040.445,304779.891 234040.272,304779.942
> 234040.099,304779.993 234039.927,304780.044 234039.754,304780.095
> 234039.582,304780.147 234039.409,304780.199 234039.236,304780.25
> 234039.064,304780.302 234038.892,304780.354 234038.719,304780.406
> 234038.547,304780.459 234038.375,304780.511 234038.201,304780.563
> 234038.03,304780.616 234037.858,304780.669 234037.686,304780.722
> 234037.514,304780.775 234037.342,304780.828 234037.17,304780.882
> 234036.998,304780.935 234036.826,304780.989 234036.654,304781.043
> 234036.482,304781.097 234036.31,304781.151 234036.138,304781.205
> 234035.967,304781.259 234035.795,304781.314 234035.623,304781.368
> 234035.452,304781.423 234035.28,304781.478 234035.109,304781.533
> 234034.937,304781.588 234034.766,304781.643 234034.594,304781.699
> 234034.423,304781.754 234034.252,304781.81 234034.081,304781.866
> 234033.909,304781.922 234033.737,304781.978 234033.566,304782.034
> 234033.396,304782.09 234033.225,304782.147 234033.054,304782.204
> 234032.883,304782.26 234032.712,304782.317 234032.541,304782.374
> 234032.371,304782.432 234032.2,304782.489 234032.029,304782.604
> 234031.688,304784.413 234026.815,304784.583 234025.197,304784.841
> 234022.038))"
> 759;6735;6677;"MULTILINESTRING((304823.67 234143.838,304819.489
> 234131.551,304812.991 234114.617,304808.097 234100.855,304804.018
> 234089.611,304801.941 234084.949,304800 234080.622,304798.745
> 234077.824,304797.911 234076.428,304795.02 234072.572,304794.836
> 234072.316,304794.743 234072.189,304794.65 234072.062,304794.556
> 234071.935,304794.461 234071.809,304794.366 234071.683,304794.27
> 234071.558,304794.175 234071.433,304794.077 234071.309,304793.979
> 234071.185,304793.881 234071.061,304793.783 234070.938,304793.684
> 234070.815,304793.584 234070.693,304793.484 234070.571,304793.383
> 234070.45,304793.282 234070.329,304793.18 234070.208,304793.078
> 234070.088,304792.975 234069.969,304792.872 234069.85,304792.768
> 234069.732,304792.663 234069.614,304792.558 234069.496,304792.453
> 234069.379,304792.347 234069.262,304792.24 234069.146,304792.133
> 234069.03,304792.025 234068.915,304791.917 234068.8,304791.809
> 234068.686,304791.699 234068.572,304791.59 234068.459,304791.479
> 234068.346,304791.369 234068.234,304791.258 234068.122,304791.146
> 234068.011,304791.034 234067.9,304790.921 234067.79,304790.808
> 234067.68,304790.694 234067.571,304790.58 234067.462,304790.465
> 234067.354,304790.35 234067.246,304790.235 234067.139,304790.118
> 234067.032,304790.002 234066.926,304789.885 234066.82,304789.767
> 234066.715,304789.649 234066.611,304789.531 234066.507,304789.412
> 234066.403,304789.292 234066.3,304789.173 234066.198,304789.052
> 234066.096,304788.932 234065.994,304788.81 234065.894,304788.689
> 234065.793,304788.566 234065.693,304788.444 234065.595,304788.321
> 234065.496,304788.197 234065.398,304788.074 234065.3,304787.949
> 234065.203,304787.824 234065.107,304787.699 234065.011,304787.574
> 234064.916,304787.447 234064.821,304787.321 234064.727,304782.475
> 234060.557,304779.648 234057.624))"
> 758;2122;2732;"MULTILINESTRING((304779.469357886
> 228169.531996587,304800 228148.409,304847.418 228101.887,304851.576
> 228097.375,304859.516 228088.758,304870.403 228077.893))"
> 757;2122;14810;"MULTILINESTRING((304779.469357886
> 228169.531996587,304798.047 228188.536,304800 228190.627,304823.838
> 228217.962,304836.749 228234.137,304843.198 228242.261,304849.312
> 228249.962,304861.874 228266.489,304872.692 228281.61,304885.604
> 228301.302,304902.005 228328.027,304904.533 228332.061))"
> 133;3958;6629;"MULTILINESTRING((303938.956 234606.428,303917.994
> 234601.507,303913.705 234600.471,303852.037 234585.571,303848.955
> 234584.697))"
> 132;3342;2238;"MULTILINESTRING((303896.759 234323.729,303879.022
> 234310.116,303874.897 234308.466,303872.834 234308.466,303869.534
> 234308.879,303865.409 234310.529,303848.085 234319.191))"
> 131;416;12986;"MULTILINESTRING((303965.74 229707.329,303875.92
> 229746.28,303847.74 229786.84))"
> 130;7233;3409;"MULTILINESTRING((303845.674 232881.49,303861.009
> 232881.49,303874.244 232882.337,303885.798 232881.914,303898.192
> 232881.702,303904.284 232882.549,303910.586 232896.944,303914.062
> 232921.465))"
> 111;6571;14214;"MULTILINESTRING((303804.663 234157.77,303813.999
> 234148.393,303821.629 234141.348))"
> 108;13143;11727;"MULTILINESTRING((303801.341 233214.634,303810.748
> 233208.974))"
> 107;13143;7930;"MULTILINESTRING((303801.341 233214.634,303807.423
> 233225.015,303813.112 233233.886,303817.696 233238.413,303820.655
> 233239.766))"
> 106;6209;4648;"MULTILINESTRING((303798.797 233823.753,303826.14
> 233810.242,303838.03 233803.534,303845.28 233800.312))"
> 602;10821;8922;"MULTILINESTRING((304624.166 233950.73,304629.284
> 233945.475,304629.376 233945.32,304629.468 233945.166,304629.562
> 233945.012,304629.657 233944.859,304629.753 233944.706,304629.85
> 233944.555,304629.949 233944.404,304630.048 233944.254,304630.148
> 233944.104,304630.25 233943.955,304630.353 233943.807,304630.456
> 233943.66,304630.561 233943.514,304630.667 233943.368,304630.774
> 233943.223,304630.882 233943.079,304630.99 233942.935,304631.1
> 233942.793,304631.211 233942.651,304631.324 233942.51,304631.437
> 233942.37,304631.551 233942.23,304631.666 233942.092,304631.782
> 233941.954,304631.899 233941.817,304632.017 233941.681,304632.136
> 233941.546,304632.256 233941.412,304632.377 233941.278,304632.499
> 233941.146,304632.622 233941.013,304632.746 233940.883,304632.871
> 233940.754,304632.996 233940.625,304633.123 233940.497,304633.251
> 233940.37,304633.379 233940.244,304633.509 233940.118,304633.639
> 233939.994,304633.77 233939.871,304633.902 233939.748,304634.035
> 233939.627,304634.169 233939.506,304634.304 233939.387,304634.44
> 233939.268,304634.576 233939.151,304634.713 233939.034,304634.852
> 233938.919,304634.991 233938.804,304635.13 233938.691,304635.271
> 233938.578,304635.411 233938.467,304635.555 233938.357,304635.698
> 233938.247,304635.842 233938.139,304635.986 233938.031,304636.132
> 233937.925,304636.278 233937.82,304636.425 233937.716,304636.573
> 233937.613,304636.721 233937.511,304636.87 233937.41,304637.02
> 233937.31,304637.171 233937.211,304637.322 233937.114,304637.474
> 233937.017,304637.627 233936.922,304637.78 233936.827,304638.089
> 233936.642,304645.242 233932.785,304651.023 233929.584,304656.757
> 233926.763,304662.007 233924.133))"
> 601;10821;1661;"MULTILINESTRING((304624.166 233950.73,304627.93
> 233953.84,304628.029 233953.916,304628.127 233953.993,304628.224
> 233954.071,304628.321 233954.15,304628.417 233954.23,304628.512
> 233954.311,304628.607 233954.393,304628.7 233954.475,304628.793
> 233954.559,304628.885 233954.643,304628.976 233954.728,304629.066
> 233954.814,304629.156 233954.9,304629.245 233954.988,304629.332
> 233955.077,304629.419 233955.167,304629.505 233955.258,304629.591
> 233955.349,304629.675 233955.441,304629.759 233955.534,304629.841
> 233955.627,304629.923 233955.722,304630.004 233955.817,304630.084
> 233955.913,304630.163 233956.009,304630.241 233956.107,304630.318
> 233956.205,304630.394 233956.304,304630.469 233956.403,304630.543
> 233956.504,304630.617 233956.605,304630.689 233956.706,304630.76
> 233956.809,304630.831 233956.912,304630.9 233957.016,304630.968
> 233957.12,304631.036 233957.225,304631.102 233957.331,304631.167
> 233957.437,304631.232 233957.544,304631.295 233957.652,304631.357
> 233957.76,304631.418 233957.869,304631.479 233957.978,304631.538
> 233958.088,304631.596 233958.198,304631.653 233958.309,304631.709
> 233958.421,304631.764 233958.533,304631.817 233958.646,304631.87
> 233958.759,304631.922 233958.872,304631.972 233958.987,304632.022
> 233959.101,304632.07 233959.216,304632.117 233959.332,304632.164
> 233959.448,304632.209 233959.564,304632.253 233959.681,304632.295
> 233959.798,304632.337 233959.916,304632.378 233960.034,304632.417
> 233960.152,304632.455 233960.271,304632.492 233960.39,304632.528
> 233960.51,304632.563 233960.63,304632.597 233960.75,304632.661
> 233960.991,304634.288 233966.106,304638.812 233979.1,304639.97
> 233982.639))"
> 600;3252;9535;"MULTILINESTRING((304622.671 233506.685,304622.99
> 233506.692,304623.308 233506.696,304623.627 233506.698,304623.946
> 233506.697,304624.265 233506.693,304624.584 233506.686,304624.902
> 233506.677,304625.221 233506.664,304625.539 233506.649,304625.858
> 233506.632,304626.176 233506.611,304626.494 233506.588,304626.811
> 233506.562,304627.129 233506.533,304627.446 233506.501,304627.763
> 233506.467,304628.08 233506.43,304628.396 233506.39,304628.712
> 233506.347,304629.028 233506.302,304629.343 233506.254,304629.657
> 233506.203,304629.972 233506.15,304630.286 233506.093,304630.599
> 233506.034,304630.912 233505.973,304631.224 233505.908,304631.535
> 233505.841,304631.847 233505.771,304632.157 233505.699,304632.467
> 233505.624,304632.776 233505.546,304633.084 233505.465,304633.392
> 233505.382,304633.699 233505.296,304634.005 233505.207,304634.311
> 233505.116,304634.615 233505.022,304634.919 233504.926,304635.222
> 233504.826,304635.524 233504.725,304635.826 233504.62,304636.126
> 233504.513,304636.425 233504.404,304636.724 233504.291,304637.021
> 233504.176,304637.317 233504.059,304637.613 233503.939,304637.907
> 233503.817,304638.2 233503.691,304638.493 233503.564,304638.784
> 233503.434,304639.073 233503.301,304639.362 233503.166,304639.65
> 233503.027,304639.936 233502.888,304640.221 233502.745,304640.505
> 233502.6,304640.788 233502.453,304641.069 233502.303,304641.349
> 233502.15,304641.627 233501.995,304641.905 233501.838,304642.181
> 233501.678,304642.455 233501.516,304642.728 233501.351,304643
> 233501.185,304643.27 233501.015,304643.806 233500.67,304644.098
> 233500.519,304644.389 233500.368,304644.681 233500.216,304644.971
> 233500.064,304645.262 233499.911,304645.553 233499.757,304645.843
> 233499.604,304646.133 233499.449,304646.422 233499.294,304646.712
> 233499.139,304647.001 233498.983,304647.29 233498.826,304647.578
> 233498.669,304647.866 233498.512,304648.154 233498.354,304648.442
> 233498.195,304648.729 233498.037,304649.017 233497.877,304649.303
> 233497.717,304649.59 233497.557,304649.876 233497.396,304650.162
> 233497.234,304650.448 233497.072,304650.734 233496.91,304651.019
> 233496.747,304651.303 233496.583,304651.588 233496.419,304651.872
> 233496.255,304652.156 233496.09,304652.44 233495.925,304652.724
> 233495.759,304653.007 233495.592,304653.289 233495.425,304653.572
> 233495.258,304653.854 233495.09,304654.136 233494.921,304654.418
> 233494.752,304654.699 233494.583,304654.98 233494.413,304655.262
> 233494.243,304655.542 233494.072,304655.822 233493.9,304656.102
> 233493.728,304656.381 233493.556,304656.66 233493.382,304656.939
> 233493.209,304657.218 233493.036,304657.496 233492.861,304657.774
> 233492.687,304658.052 233492.511,304658.33 233492.335,304658.607
> 233492.159,304658.884 233491.982,304659.16 233491.805,304659.436
> 233491.627,304659.712 233491.449,304659.988 233491.27,304660.263
> 233491.091,304660.538 233490.911,304660.812 233490.731,304661.087
> 233490.551,304661.361 233490.369,304661.634 233490.188,304661.908
> 233490.006,304662.181 233489.823,304662.453 233489.64,304662.726
> 233489.456,304662.998 233489.272,304663.541 233488.903,304668.194
> 233485.961,304672.321 233483.964,304680.263 233475.849,304682.211
> 233473.429,304683.293 233471.512,304684.888 233468.087,304687.119
> 233463.993,304689.079 233461.242,304690.716 233459.119,304691.851
> 233458.092,304693.498 233456.847,304695.534 233455.673,304697.625
> 233454.714,304701.189 233453.542,304705.744 233452.566,304709.511
> 233451.903,304712.766 233451.682,304717.197 233451.556,304719.093
> 233451.596,304720.743 233451.939,304722.577 233452.768,304723.098
> 233453.093,304723.636 233453.675,304724.209 233454.432,304724.775
> 233455.634,304725.831 233458.423,304726.465 233460.567,304736.305
> 233492.381,304743.304 233514.741,304743.805 233516.167,304744.282
> 233517.878,304744.654 233520.752,304744.818 233521.982,304744.007
> 233532.055))"
> 599;8860;2319;"MULTILINESTRING((304622.11 233459.818,304632.748
> 233447.671,304641.194 233439.489,304641.285 233439.386,304641.375
> 233439.282,304641.464 233439.176,304641.551 233439.07,304641.638
> 233438.962,304641.722 233438.854,304641.806 233438.744,304641.888
> 233438.633,304641.968 233438.522,304642.048 233438.408,304642.125
> 233438.296,304642.202 233438.181,304642.277 233438.065,304642.35
> 233437.949,304642.423 233437.832,304642.493 233437.713,304642.562
> 233437.594,304642.63 233437.474,304642.696 233437.354,304642.761
> 233437.232,304642.824 233437.11,304642.886 233436.986,304642.946
> 233436.863,304643.005 233436.738,304643.062 233436.613,304643.117
> 233436.486,304643.171 233436.36,304643.223 233436.232,304643.274
> 233436.104,304643.323 233435.976,304643.371 233435.846,304643.417
> 233435.717,304643.461 233435.586,304643.504 233435.455,304643.546
> 233435.324,304643.584 233435.192,304643.622 233435.059,304643.66
> 233434.926,304643.693 233434.793,304643.726 233434.659,304643.757
> 233434.525,304643.787 233434.391,304643.815 233434.256,304643.841
> 233434.121,304643.866 233433.985,304643.888 233433.849,304643.91
> 233433.712,304643.929 233433.577,304643.947 233433.44,304643.963
> 233433.303,304643.977 233433.166,304643.99 233433.029,304644.001
> 233432.892,304644.003 233432.855))"
> 598;3252;8860;"MULTILINESTRING((304622.671 233506.685,304622.515
> 233496.189,304622.66 233473.004,304622.778 233465.116,304622.11
> 233459.818))"
> 597;810;4024;"MULTILINESTRING((304622.064 231878.006,304644.189
> 231877.9,304663.844 231877.874,304674.544 231878.515,304683.191
> 231880.049,304689.586 231881.724))"
> 596;663;8635;"MULTILINESTRING((304621.251 235149.758,304623.164
> 235155.13,304626.662 235164.379,304629.711 235171.858,304633.697
> 235180.655,304637.107 235186.94,304640.112 235192.418,304643.133
> 235198.075))"
> 595;9398;14436;"MULTILINESTRING((304628.334 233646.201,304628.233
> 233645.359,304621.206 233618.902))"
> 594;812;3292;"MULTILINESTRING((304654.68 231750.313,304652.929
> 231779.574,304651.875 231795.079,304650.302 231801.777,304644.091
> 231804.555,304632.886 231805.363,304620.84 231805.17))"
> 593;675;14168;"MULTILINESTRING((304619.263 234154.292,304621.677
> 234160.107,304627.654 234173.459,304633.138 234186.402,304638.994
> 234198.691,304643.423 234207.679))"
> 592;3628;5980;"MULTILINESTRING((304618.507 234027.121,304654.666
> 234015.769))"
> 591;8743;3628;"MULTILINESTRING((304637.848 234082.2,304629.86
> 234048.985,304625.987 234044.006,304623.973 234041.417,304621.451
> 234036.792,304618.507 234027.121))"
> 590;2453;13256;"MULTILINESTRING((304615.141 235131.411,304622.592
> 235129.962,304628.652 235129.07,304643.073 235127.325,304660.88
> 235124.234))"
> 589;2453;663;"MULTILINESTRING((304615.141 235131.411,304617.601
> 235139.36,304620.058 235146.409,304621.251 235149.758))"
> 588;1222;4315;"MULTILINESTRING((304962.589 235254.22,304955.279
> 235248.865,304938.178 235235.866,304919.633 235220.8,304919.372
> 235220.592,304905.306 235209.413,304890.008 235197.429,304873.498
> 235184.981,304857.517 235173.164,304840.209 235160.583,304800
> 235133.053,304763.242 235107.933,304744.854 235095.316,304739.237
> 235091.305,304727.72 235083.083,304710.247 235070.763,304693.615
> 235058.478,304677.017 235046.454,304661.992 235034.919,304650.55
> 235027.515,304646.757 235025.061,304629.198 235013.12,304614.328
> 235019.138))"
> 587;13834;4315;"MULTILINESTRING((304902.649 235329.346,304898.105
> 235325.235,304891.564 235319.058,304878.972 235305.781,304863.032
> 235288.34,304860.262 235285.419,304842.642 235266.835,304800
> 235221.87,304747.949 235167.581,304728.049 235147.733,304705.596
> 235125.098,304692.741 235111.98,304687.839 235106.308,304674.869
> 235091.747,304654.405 235069.828,304614.328 235019.138))"
> 586;11620;4315;"MULTILINESTRING((304931.073 235291.733,304904.524
> 235269.57,304898.414 235264.316,304874.369 235243.426,304844.725
> 235217.79,304800 235179.112,304742.288 235129.234,304733.419
> 235121.511,304724.335 235113.563,304716.508 235106.899,304703.26
> 235095.596,304691.077 235085.191,304680.726 235076.401,304614.328
> 235019.138))"
> 585;9571;10821;"MULTILINESTRING((304613.648 233961.334,304618.606
> 233956.057,304624.166 233950.73))"
> 584;11424;8677;"MULTILINESTRING((304642.553 234393.351,304637.7
> 234386.315,304623.028 234366.974,304617.846 234359.563,304613.294
> 234352.942))"
> 580;9631;12881;"MULTILINESTRING((304614.65 234263.935,304607.8
> 234255.604,304603.703 234248.654))"
> 779;9600;2904;"MULTILINESTRING((304810.187 229263.839,304866.856
> 229285.636,304870.227 229287.827))"
> 778;14712;9600;"MULTILINESTRING((305040.039 229172.433,305020.256
> 229184.227,304980.072 229207.645,304924.557 229239.912,304896.251
> 229255.268,304886.506 229259.919,304884.08 229261.077,304870.627
> 229261.877,304858.321 229263.432,304842.117 229264.222,304810.187
> 229263.839))"
> 777;1874;5939;"MULTILINESTRING((304805.384 231372.346,304807.846
> 231362.742,304812.525 231354.37,304818.435 231347.968,304824.345
> 231343.781,304834.687 231341.073,304844.045 231342.058,304852.91
> 231344.274,304859.558 231347.968,304902.024 231372.806))"
> 776;1874;3656;"MULTILINESTRING((304805.384 231372.346,304811.54
> 231376.778,304851.233 231400))"
> Run the copy and pasted query in PHP and get the result:
> <route>
>> <edge>
> <gid>761</gid>
> <source>6780</source>
> <target>8203</target>
>> <wkt>
> MULTILINESTRING((304782.351 234010.52,304784.841 234022.038))
> </wkt>
> </edge>
>> <edge>
> <gid>760</gid>
> <source>6677</source>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>759</gid>
> <source>6735</source>
> <target>6677</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>758</gid>
> <source>2122</source>
> <target>2732</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>757</gid>
> <target>14810</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>133</gid>
> <source>3958</source>
> <target>6629</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>132</gid>
> <source>3342</source>
> <target>2238</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>131</gid>
> <source>416</source>
> <target>12986</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>130</gid>
> <source>7233</source>
> <target>3409</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>111</gid>
> <source>6571</source>
> <target>14214</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>108</gid>
> <source>13143</source>
> <target>11727</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>107</gid>
> <target>7930</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>106</gid>
> <source>6209</source>
> <target>4648</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>602</gid>
> <source>10821</source>
> <target>8922</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>601</gid>
> <target>1661</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>600</gid>
> <source>3252</source>
> <target>9535</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>599</gid>
> <source>8860</source>
> <target>2319</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>598</gid>
> <target>8860</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>597</gid>
> <source>810</source>
> <target>4024</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>596</gid>
> <source>663</source>
> <target>8635</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>595</gid>
> <source>9398</source>
> <target>14436</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>594</gid>
> <source>812</source>
> <target>3292</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>593</gid>
> <source>675</source>
> <target>14168</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>592</gid>
> <source>3628</source>
> <target>5980</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>591</gid>
> <source>8743</source>
> <target>3628</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>590</gid>
> <source>2453</source>
> <target>13256</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>589</gid>
> <target>663</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>588</gid>
> <source>1222</source>
> <target>4315</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>587</gid>
> <source>13834</source>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>586</gid>
> <source>11620</source>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>585</gid>
> <source>9571</source>
> <target>10821</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>584</gid>
> <source>11424</source>
> <target>8677</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>580</gid>
> <source>9631</source>
> <target>12881</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>779</gid>
> <source>9600</source>
> <target>2904</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>778</gid>
> <source>14712</source>
> <target>9600</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>777</gid>
> <source>1874</source>
> <target>5939</target>
>> <wkt>
> </wkt>
> </edge>
>> <edge>
> <gid>776</gid>
> <target>3656</target>
>> <wkt>
> </wkt>
> </edge>
> </route>
> As you can see for some of the edges the geometry returned is smaller.
> Edge with GID 760 wkt is:
> PGADMIN:
> 234022.038))"
> PHP Script:
> In PHP I'm using $wkt = pg_result($spf, 0, 3) to retrieve the
> individual fields.
> Does anybody know why this is happening? Is it something I'm doing wrong?
> Thanks for the help
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
