[OpenLayers-Users] Help: Wrong coordinates after map position
changed
kgm
kirsten.grimm at geops.de
Thu Mar 20 08:19:15 EDT 2008
Hello,
I have a map where the user can add or edit features.
It is possible, that the map container changes its position in the Layout.
After this has happened I have the following problem:
The mouseclick is registered at the position where the map was before being
moved, so if I add a Feature at some position, it is not added where I click
but moved by the offset of which the map was moved.
What can I do about this?
Thanks in advance,
Kirsten
View this message in context: http://www.nabble.com/Help%3A-Wrong-coordinates-after-map-position-changed-tp16001333p16001333.html
