[OpenLayers-Users] How to find if Point is within Polygon??
Eric Lemoine
eric.c2c at gmail.com
Sat Mar 22 19:36:02 EDT 2008
On Sat, Mar 22, 2008 at 11:48 PM, plen <peteralen at earthlink.net> wrote:
> Hello,
> I have polyogns defined by:
> var polygon = new OpenLayers.Geometry.Polygon([linearRing]);
> Later, when the user clicks on the map, I can get the lat/long of the map
> click and create a Point via:
> var point = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
> The goal is to see if the point is within the polygon area.
> I saw that there is a containsPoint(Point) method for the Polygon when I
> look at the OpenLayers API docs at:
> http://dev.openlayers.org/docs/files/OpenLayers/Geometry/Polygon-js.html
> This API shows functions, properties, etc that may not be exposed to the
> regular API which is listed at:
> http://dev.openlayers.org/apidocs/files/OpenLayers/Geometry/Polygon-js.html
> When I ran my code, I get an error that states that
> OpenLayers.Geometry.Polygon does not have a containsPoint function.
> I then tried to use the OpenLayers.Geometry.Polygon.intersects() method
> since that was listed in the base API docs. This function takes an
> OpenLayers.Geometry object and since the point is created as
> OpenLayers.Geometry.Point, I thought that might work. But again, I got the
> error that OpenLayers.Geometry.Polygon does not have an intersect function.
> I am at a loss now. This must be a common problem. How can I check to see
> if my point is within any of my polygons?
Hi Plen
What OL version are you using? The API doc corresponds to what's in
trunk, and you're not using trunk AFACT.
Cheers,
Eric
