[OpenLayers-Users] Tooltip
Gregor Mosheh gregor at hostgis.com
Fri Mar 28 08:21:40 EDT 2008
Gérald Quintana wrote:
> Is it possible to display a tooltip when the mouse stops moving over the map?
I posted my responses a few weeks ago, along with some working code.
Check the archives and ask again if you can't find it.
The basic outline is:
- add a mousemove handler to the map object
- the event handler saves the event to a variable, and does a
clearTimeout() and setTimeout() to keep from firing the handler a
zillion times when someone sneezes
- the timeout's handler reads the variable and does basically the same
as you would for a click event
As far as I could tell, the map itself didn't have a hover event, that
was only for vector objects. If I'm wrong about that and the map does
have a hover event, I'd love to be corrected because that could simplify
my approach significantly.
Gregor Mosheh / Greg Allensworth, BS, A+
System Administrator
HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
