[OpenLayers-Users] Tooltip
Christopher Schmidt crschmidt at metacarta.com
Fri Mar 28 08:50:21 EDT 2008
On Fri, Mar 28, 2008 at 06:21:40AM -0600, Gregor Mosheh wrote:
> Gérald Quintana wrote:
> > Is it possible to display a tooltip when the mouse stops moving over the map?
> I posted my responses a few weeks ago, along with some working code.
> Check the archives and ask again if you can't find it.
> The basic outline is:
> - add a mousemove handler to the map object
> - the event handler saves the event to a variable, and does a
> clearTimeout() and setTimeout() to keep from firing the handler a
> zillion times when someone sneezes
> - the timeout's handler reads the variable and does basically the same
> as you would for a click event
This seems a lot harder than it needs to be, since after the last
request we added a handler to trunk which does all this for you:
http://openlayers.org/dev/examples/hover-handler.html
Regards,
Christopher Schmidt
MetaCarta
