[OpenLayers-Users] popups
Christopher Schmidt crschmidt at metacarta.com
Mon Mar 31 07:27:06 EDT 2008
On Mon, Mar 31, 2008 at 01:19:17PM +0200, Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> just upgraded to trunk and have some trouble with my popups. They are
> created using feature.createPopup(true).
> Problems I have:
> -closebox image is no longer visible
I'm assuming you have a different ImgPath or something than the
OpenLayers default? We were just discussing that in #1472: have you
customized the close.gif at all, or were you just using the default one
in a different place?
(This is now committed, so 'svn up' should help you here.)
> -there is a bigger white rim around the popup now, on the right and bottom
I'm surprised by the 'bottom' part of this: the 'right' part is somewhat
expected, since we now ensure that the closebox isn't covering the
content. I'm guessing you feel that this is a regression.
Can you link a copy of the current code? Perhaps even one that is using
the older code as well?
Thanks,
Christopher Schmidt
MetaCarta
