[OpenLayers-Users] popups
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Mon Mar 31 08:13:24 EDT 2008
Hi Chris,
I was using a different close.gif, so I had to copy the new lines of css for
the olPopupCloseBox class into my css file to get the closebox. But as you
say, it's now outside of the popup content, which is a bit unexpected for
me.
The old situation:
http://www.rijkswaterstaat.nl/apps/geoservices/mapviewer2/
The new situation:
http://www.rijkswaterstaat.nl/apps/geoservices/mapviewer2/index_oltrunk.html
Use the fifth tool in the toolbar (the one that looks like i) and click in
the map to get the popup.
TIA.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Christopher Schmidt <crschmidt at metacarta.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] popups
Datum: 31/03/08 09:51
> On Mon, Mar 31, 2008 at 01:19:17PM +0200, Bart van den Eijnden (OSGIS)
wrote:
> &gt; Hi list,
> &gt;
> &gt; just upgraded to trunk and have some trouble with my popups. They are
> &gt; created using feature.createPopup(true).
> &gt;
> &gt; Problems I have:
> &gt; -closebox image is no longer visible
> I'm assuming you have a different ImgPath or something than the
> OpenLayers default? We were just discussing that in #1472: have you
> customized the close.gif at all, or were you just using the default one
> in a different place?
> (This is now committed, so 'svn up' should help you here.)
> &gt; -there is a bigger white rim around the popup now, on the right and
bottom
> I'm surprised by the 'bottom' part of this: the 'right' part is somewhat
> expected, since we now ensure that the closebox isn't covering the
> content. I'm guessing you feel that this is a regression.
> Can you link a copy of the current code? Perhaps even one that is using
> the older code as well?
> Thanks,
> Christopher Schmidt
> MetaCarta
