[OpenLayers-Users] popups
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Mon Mar 31 08:38:00 EDT 2008
I can get the closebox back to its original position using css:
.olPopupCloseBox {
  background: url("../geoservices2/lib/openlayers/img/close.gif") no-repeat;
  cursor: pointer;
  right: 15px !important;
  top: 5px !important;
Setting OpenLayers.Popup.COLOR = 'transparent' hides the "bigger popup"
issue for me, which is fine by me.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Naar: Christopher Schmidt <crschmidt at metacarta.com>, Bart van den Eijnden
Cc: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] popups
Datum: 31/03/08 10:13
> Hi Chris,
> I was using a different close.gif, so I had to copy the new lines of css
for
> the olPopupCloseBox class into my css file to get the closebox. But as you
> say, it's now outside of the popup content, which is a bit unexpected for
> me.
> The old situation:
> http://www.rijkswaterstaat.nl/apps/geoservices/mapviewer2/
> The new situation:
http://www.rijkswaterstaat.nl/apps/geoservices/mapviewer2/index_oltrunk.html
> Use the fifth tool in the toolbar (the one that looks like i) and click in
> the map to get the popup.
> TIA.
> Best regards,
> Bart
> http://www.osgis.nl
> Van: Christopher Schmidt &lt;crschmidt at metacarta.com&gt;
> Naar: Bart van den Eijnden OSGIS &lt;bartvde at osgis.nl&gt;
> Datum: 31/03/08 09:51
> &gt; On Mon, Mar 31, 2008 at 01:19:17PM +0200, Bart van den Eijnden
(OSGIS)
> wrote:
> &gt; &amp;gt; Hi list,
> &gt; &amp;gt;
> &gt; &amp;gt; just upgraded to trunk and have some trouble with my popups.
They are
> &gt; &amp;gt; created using feature.createPopup(true).
> &gt; &amp;gt;
> &gt; &amp;gt; Problems I have:
> &gt; &amp;gt; -closebox image is no longer visible
> &gt;
> &gt; I'm assuming you have a different ImgPath or something than the
> &gt; OpenLayers default? We were just discussing that in #1472: have you
> &gt; customized the close.gif at all, or were you just using the default
one
> &gt; in a different place?
> &gt;
> &gt; (This is now committed, so 'svn up' should help you here.)
> &gt;
> &gt; &amp;gt; -there is a bigger white rim around the popup now, on the
right and
> bottom
> &gt;
> &gt; I'm surprised by the 'bottom' part of this: the 'right' part is
somewhat
> &gt; expected, since we now ensure that the closebox isn't covering the
> &gt; content. I'm guessing you feel that this is a regression.
> &gt;
> &gt; Can you link a copy of the current code? Perhaps even one that is
using
> &gt; the older code as well?
> &gt;
> &gt; Thanks,
> &gt; --
> &gt; Christopher Schmidt
> &gt; MetaCarta
> &gt;
> &gt;
