[OpenLayers-Users] http protocol problem
Didrik Pinte lists at dipole-consulting.com
Wed Nov 5 09:47:11 EST 2008
On Wed, 2008-11-05 at 09:30 -0500, Christopher Schmidt wrote:
> On Wed, Nov 05, 2008 at 06:26:16AM -0800, Jerome Freyre wrote:
> > Hi Didrik,
> > It is strange... I do almost the same thing and it is working...
> > The only change is that I use the OpenLayers.Strategy.Fixed() and
> > OpenLayers.Strategy.Cluster()
> Yes, you need to use a strategy that requests features. Cluster does
> not. Fixed does. So use a Fixed strategy, and a cluster strategy:
Hi Christopher,
Thanks for the information. Adding the Fixed strategy solved the
problem.
Now, it seems that my callback function that centers the map on the
loaded data is not called since I use the Fixed layer (because Fixed
overload the callback using its merge method ? ).
Jerome, thanks for you answer. We have the explanation thanks to
Christopher.
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081105/e52f26ff/attachment.bin
