[OpenLayers-Users] http protocol problem
Eric Lemoine eric.c2c at gmail.com
Wed Nov 5 17:23:32 EST 2008
Hi. How do you register your callback? Sorry i don't see what you're
talking about. Eric
2008/11/5, Didrik Pinte <lists at dipole-consulting.com>:
> On Wed, 2008-11-05 at 09:30 -0500, Christopher Schmidt wrote:
>> On Wed, Nov 05, 2008 at 06:26:16AM -0800, Jerome Freyre wrote:
>> > Hi Didrik,
>> > It is strange... I do almost the same thing and it is working...
>> > The only change is that I use the OpenLayers.Strategy.Fixed() and
>> > OpenLayers.Strategy.Cluster()
>> Yes, you need to use a strategy that requests features. Cluster does
>> not. Fixed does. So use a Fixed strategy, and a cluster strategy:
> Hi Christopher,
> Thanks for the information. Adding the Fixed strategy solved the
> problem.
> Now, it seems that my callback function that centers the map on the
> loaded data is not called since I use the Fixed layer (because Fixed
> overload the callback using its merge method ? ).
> Jerome, thanks for you answer. We have the explanation thanks to
> Christopher.
> Didrik
