[OpenLayers-Users] Pass parameters to mapfile
Bijoy K. Anupam bijoya at rediff.co.in
Mon Nov 10 05:22:14 EST 2008
Reena,
As per my understanding, I assume you want to pass dynamic value in the URL.
Can you try defining like the way I have done below:-
wms[5] = new
OpenLayers.Layer.WMS.Untiled("Customization","http://gis.rtbi-iitm.in/cgi-bi
n/mapserv?map=/var/www/html/customisation/mapfile/customNR.map&userid="+
user_id,{'layers':
'NR_point,NR_polygon,NR_line','transparent':"true"},{'isBaseLayer':false} );
Let me know if this solves, else go under OpenLayers.Layer.WMS.Untiled class
and try and find out what URL is being passed. You might have to use the
library files.
Thanks,
With Regards,
BIJOY K. ANUPAM
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of S.Reena
Sent: Monday, November 10, 2008 3:06 PM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] Pass parameters to mapfile
I already tried with
 wms[5] = new OpenLayers.Layer.WMS.Untiled(
"Customization","http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/c
ustomisation/mapfile/customNR.map&userid=2",{'layers':
It works fine with static value but not with dynamic values like
userid=user_id...
I think you were trying to suggest this only and if not then plz let me
correct myself...
Thanks,
Reena.
G. Tiemens wrote:
> Hi,
> Your mapserver url can be extended with this paramter.. Try:
>    "http://yourserv/mapserv?userid=" + customuserid + "&"
> Greets
> Gerben
> -----Oorspronkelijk bericht-----
> Van: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> Namens S.Reena
> Verzonden: Monday, November 10, 2008 9:18 AM
> Aan: users at openlayers.org
> Onderwerp: Re: [OpenLayers-Users] Pass parameters to mapfile
> Hi,
> I tried as :
> var quakes = new OpenLayers.Layer.WMS( "custom",
> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?",
{map:'/var/www/html/customisation/mapfile/tnroad.map',transparent:true},{isB
aseLayer:false});
>  map.addLayer(quakes);
>  quakes.mergeNewParams({layers:'tnroad',userid:'2'});
> But mergeNewParams is not taking any value other than defaults for map
> (like in this case userid ). So %userid% is not replaced  in
>   DATA "the_geom from ( select * from customised_poly AS f where
> f.subcat_id IN (select subcat_id from subcat_info where maincat_id =0) AND
> user_id=%userid% )AS foo1 USING UNIQUE gid"
> Thanks,
> Reena.
> Arnd Wippermann wrote:
>> Hi,
>> If you have declared the variable user_id before mergeNewParams, it
>> should also work.
>> Because it is a Mapserver question, try and manipulate the request in
>> the browser and see what MapServer returns. If you get the response,
>> you want, then it is possible to get it also with OpenLayers.
>> Arnd Wippermann
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org
>> [mailto:users-bounces at openlayers.org] Im Auftrag von S.Reena
>> Gesendet: Samstag, 8. November 2008 14:05
>> An: users at openlayers.org
>> Betreff: Re: [OpenLayers-Users] Pass parameters to mapfile
>> Hi,
>> One issue remains still ..
>> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisati
>> on/map
>> is working ok with
>> AND user_id='%userid%' )AS foo1 USING UNIQUE gid"
>> but is I want to pass a dynamic value( a variable user_id) instead of
>> a number ( in this case 2) then its not happening .
>> I am still trying with wms[5].mergeNewParams({userid:user_id}) but its
>> not working yet
>> Thanks,
>> Reena.
>>> You can try to add the param to the url
>>> i
>>> on/map
>>> file/customNR.map&userid=anID"
>>> and in the mapfile try user_id='%userid%'. In special cases it is
>>> possible per cgi-parameter manipulate the mapfile. I don't no if this
>>> case is one of them.
>>> Try the mapserver-list, because it is not an OpenLayers issue.
>>> To retrieve more than one layer with OpenLayers WMS you use
>>> {'layers' : 'NR_point,NR_polygon', 'transparent' : true, ... }, ...
>>> a comma-separatet list as christopher mentioned.
>>> Arnd Wippermann
>>> Gesendet: Freitag, 7. November 2008 10:39
>>> Betreff: [OpenLayers-Users] Pass parameters to mapfile
>>> I am using the following data in my mapfile
>>>  DATA "the_geom from ( select * from customised_point AS f where
>>> user_id='userid' AND f.subcat_id IN (select subcat_id from
>>> subcat_info where maincat_id =0))AS foo USING UNIQUE gid"
>>> I want the userid ( used in the above query) to be passed to map file
>>> at the time of layer creation something like this....
>>> html/c
>>> ustomisation/mapfile/customNR.map"
>>> + userid  ,{'layers': "NR_point",'transparent':"true"},{'layers':
>>> "NR_polygon",'transparent':"true"},{'isBaseLayer':false} );
>>> How to do that?
>>> Thanks in advance :)
>>> Cheers,
>>> Reena.
>>> View this message in context:
>>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20377405.
>>> h tml Sent from the OpenLayers Users mailing list archive at
>>> Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20395897.h
>> tml Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users mailing list
> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20415933.html
> Users mailing list
> << Please read our E-mail Disclaimer at the Grontmij Corporate website >>
> Users mailing list
http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20416691.html
Users mailing list
