[OpenLayers-Users] Pass parameters to mapfile
S.Reena reena at indiamail.com
Mon Nov 10 08:56:42 EST 2008
Thanks Bijoy...
It already worked for me as Gerben suggested :
 nres = new OpenLayers.Layer.WMS.Untiled(
                "Natural Resources",
"http://gis.rtbi-iitm.in/cgi-bin/mapserv?userid="+user_id +"&",
{map:'/var/www/html/customisation/mapfile/customNR.map',transparent:true},{layers:'NR_point,NR_polygon,NR_line'},
{isBaseLayer:false});
                map.addLayer(nres);
Regards,
Reena.
Bijoy wrote:
> Reena,
> As per my understanding, I assume you want to pass dynamic value in the
> URL.
> Can you try defining like the way I have done below:-
> wms[5] = new
> OpenLayers.Layer.WMS.Untiled("Customization","http://gis.rtbi-iitm.in/cgi-bi
> n/mapserv?map=/var/www/html/customisation/mapfile/customNR.map&userid="+
> user_id,{'layers':
> 'NR_point,NR_polygon,NR_line','transparent':"true"},{'isBaseLayer':false}
> Let me know if this solves, else go under OpenLayers.Layer.WMS.Untiled
> class
> and try and find out what URL is being passed. You might have to use the
> library files.
> Thanks,
> With Regards,
> BIJOY K. ANUPAM
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> On
> Behalf Of S.Reena
> Sent: Monday, November 10, 2008 3:06 PM
> To: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Pass parameters to mapfile
> Hi,
> I already tried with
>  wms[5] = new OpenLayers.Layer.WMS.Untiled(
> "Customization","http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/c
> ustomisation/mapfile/customNR.map&userid=2",{'layers':
> It works fine with static value but not with dynamic values like
> userid=user_id...
> I think you were trying to suggest this only and if not then plz let me
> correct myself...
> Thanks,
> Reena.
> G. Tiemens wrote:
>> Hi,
>> Your mapserver url can be extended with this paramter.. Try:
>>    "http://yourserv/mapserv?userid=" + customuserid + "&"
>> Greets
>> Gerben
>> -----Oorspronkelijk bericht-----
>> Van: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> Namens S.Reena
>> Verzonden: Monday, November 10, 2008 9:18 AM
>> Aan: users at openlayers.org
>> Onderwerp: Re: [OpenLayers-Users] Pass parameters to mapfile
>> Hi,
>> I tried as :
>> var quakes = new OpenLayers.Layer.WMS( "custom",
>> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?",
> {map:'/var/www/html/customisation/mapfile/tnroad.map',transparent:true},{isB
> aseLayer:false});
>>  map.addLayer(quakes);
>>  quakes.mergeNewParams({layers:'tnroad',userid:'2'});
>> But mergeNewParams is not taking any value other than defaults for map
>> (like in this case userid ). So %userid% is not replaced  in
>>   DATA "the_geom from ( select * from customised_poly AS f where
>> f.subcat_id IN (select subcat_id from subcat_info where maincat_id =0)
>> AND
>> user_id=%userid% )AS foo1 USING UNIQUE gid"
>> Thanks,
>> Reena.
>> Arnd Wippermann wrote:
>>> Hi,
>>> If you have declared the variable user_id before mergeNewParams, it
>>> should also work.
>>> Because it is a Mapserver question, try and manipulate the request in
>>> the browser and see what MapServer returns. If you get the response,
>>> you want, then it is possible to get it also with OpenLayers.
>>> Arnd Wippermann
>>> -----Ursprüngliche Nachricht-----
>>> Von: users-bounces at openlayers.org
>>> [mailto:users-bounces at openlayers.org] Im Auftrag von S.Reena
>>> Gesendet: Samstag, 8. November 2008 14:05
>>> An: users at openlayers.org
>>> Betreff: Re: [OpenLayers-Users] Pass parameters to mapfile
>>> Hi,
>>> One issue remains still ..
>>> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisati
>>> on/map
>>> is working ok with
>>> AND user_id='%userid%' )AS foo1 USING UNIQUE gid"
>>> but is I want to pass a dynamic value( a variable user_id) instead of
>>> a number ( in this case 2) then its not happening .
>>> I am still trying with wms[5].mergeNewParams({userid:user_id}) but its
>>> not working yet
>>> Thanks,
>>> Reena.
>>>> You can try to add the param to the url
>>>> i
>>>> on/map
>>>> file/customNR.map&userid=anID"
>>>> and in the mapfile try user_id='%userid%'. In special cases it is
>>>> possible per cgi-parameter manipulate the mapfile. I don't no if this
>>>> case is one of them.
>>>> Try the mapserver-list, because it is not an OpenLayers issue.
>>>> To retrieve more than one layer with OpenLayers WMS you use
>>>> {'layers' : 'NR_point,NR_polygon', 'transparent' : true, ... }, ...
>>>> a comma-separatet list as christopher mentioned.
>>>> Arnd Wippermann
>>>> Gesendet: Freitag, 7. November 2008 10:39
>>>> Betreff: [OpenLayers-Users] Pass parameters to mapfile
>>>> I am using the following data in my mapfile
>>>>  DATA "the_geom from ( select * from customised_point AS f where
>>>> user_id='userid' AND f.subcat_id IN (select subcat_id from
>>>> subcat_info where maincat_id =0))AS foo USING UNIQUE gid"
>>>> I want the userid ( used in the above query) to be passed to map file
>>>> at the time of layer creation something like this....
>>>> html/c
>>>> ustomisation/mapfile/customNR.map"
>>>> + userid  ,{'layers': "NR_point",'transparent':"true"},{'layers':
>>>> "NR_polygon",'transparent':"true"},{'isBaseLayer':false} );
>>>> How to do that?
>>>> Thanks in advance :)
>>>> Cheers,
>>>> Reena.
>>>> View this message in context:
>>>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20377405.
>>>> h tml Sent from the OpenLayers Users mailing list archive at
>>>> Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20395897.h
>>> tml Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users mailing list
>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20415933.html
>> Users mailing list
>> << Please read our E-mail Disclaimer at the Grontmij Corporate website >>
>> Users mailing list
> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20416691.html
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20420403.html
