[OpenLayers-Users] Pass parameters to mapfile
S.Reena reena at indiamail.com
Mon Nov 10 06:28:17 EST 2008
Hey..
It worked finally..thanku so much :)
G. Tiemens wrote:
> Hi,
> Your mapserver url can be extended with this paramter.. Try:
>    "http://yourserv/mapserv?userid=" + customuserid + "&"
> Greets
> Gerben
> -----Oorspronkelijk bericht-----
> Van: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> Namens S.Reena
> Verzonden: Monday, November 10, 2008 9:18 AM
> Aan: users at openlayers.org
> Onderwerp: Re: [OpenLayers-Users] Pass parameters to mapfile
> Hi,
> I tried as :
> var quakes = new OpenLayers.Layer.WMS( "custom",
> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?",
> {map:'/var/www/html/customisation/mapfile/tnroad.map',transparent:true},{isBaseLayer:false});
>  map.addLayer(quakes);
>  quakes.mergeNewParams({layers:'tnroad',userid:'2'});
> But mergeNewParams is not taking any value other than defaults for map
> (like in this case userid ). So %userid% is not replaced  in
>   DATA "the_geom from ( select * from customised_poly AS f where
> f.subcat_id IN (select subcat_id from subcat_info where maincat_id =0) AND
> user_id=%userid% )AS foo1 USING UNIQUE gid"
> Thanks,
> Reena.
> Arnd Wippermann wrote:
>> Hi,
>> If you have declared the variable user_id before mergeNewParams, it
>> should also work.
>> Because it is a Mapserver question, try and manipulate the request in
>> the browser and see what MapServer returns. If you get the response,
>> you want, then it is possible to get it also with OpenLayers.
>> Arnd Wippermann
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org
>> [mailto:users-bounces at openlayers.org] Im Auftrag von S.Reena
>> Gesendet: Samstag, 8. November 2008 14:05
>> An: users at openlayers.org
>> Betreff: Re: [OpenLayers-Users] Pass parameters to mapfile
>> Hi,
>> One issue remains still ..
>> "http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www/html/customisati
>> on/map
>> file/customNR.map&userid=2"
>> is working ok with
>> AND user_id='%userid%' )AS foo1 USING UNIQUE gid"
>> but is I want to pass a dynamic value( a variable user_id) instead of
>> a number ( in this case 2) then its not happening .
>> I am still trying with wms[5].mergeNewParams({userid:user_id}) but its
>> not working yet
>> Thanks,
>> Reena.
>>> You can try to add the param to the url
>>> i
>>> on/map
>>> file/customNR.map&userid=anID"
>>> and in the mapfile try user_id='%userid%'. In special cases it is
>>> possible per cgi-parameter manipulate the mapfile. I don't no if this
>>> case is one of them.
>>> Try the mapserver-list, because it is not an OpenLayers issue.
>>> To retrieve more than one layer with OpenLayers WMS you use
>>> {'layers' : 'NR_point,NR_polygon', 'transparent' : true, ... }, ...
>>> a comma-separatet list as christopher mentioned.
>>> Arnd Wippermann
>>> Gesendet: Freitag, 7. November 2008 10:39
>>> Betreff: [OpenLayers-Users] Pass parameters to mapfile
>>> I am using the following data in my mapfile
>>>  DATA "the_geom from ( select * from customised_point AS f where
>>> user_id='userid' AND f.subcat_id IN (select subcat_id from
>>> subcat_info where maincat_id =0))AS foo USING UNIQUE gid"
>>> I want the userid ( used in the above query) to be passed to map file
>>> at the time of layer creation something like this....
>>> wms[5] = new OpenLayers.Layer.WMS.Untiled(
>>> "Customization","http://gis.rtbi-iitm.in/cgi-bin/mapserv?map=/var/www
>>> html/c
>>> ustomisation/mapfile/customNR.map"
>>> + userid  ,{'layers': "NR_point",'transparent':"true"},{'layers':
>>> "NR_polygon",'transparent':"true"},{'isBaseLayer':false} );
>>> How to do that?
>>> Thanks in advance :)
>>> Cheers,
>>> Reena.
>>> View this message in context:
>>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20377405.
>>> h tml Sent from the OpenLayers Users mailing list archive at
>>> Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20395897.h
>> tml Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users mailing list
> http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20415933.html
> Users mailing list
> << Please read our E-mail Disclaimer at the Grontmij Corporate website >>
> Users mailing list
View this message in context: http://www.nabble.com/Pass-parameters-to-mapfile-tp20377405p20418297.html
