[OpenLayers-Users] Question on changing Popups on Textlayer
Dirk Umlauffd Dirk.Umlauffd at web.de
Mon Nov 17 14:03:10 EST 2008
Hello Christopher,
I'm not quite sure if this will work - could you please have a look at:
http://dtumlauffd.mine.nu/tmp_test/kopie_textseite.html
http://dtumlauffd.mine.nu/tmp_test/kopie1_textseite.html
The first one is working, the second one not - the second one is made with the OpenLayers.Layer.GML example.
Both with the same textfile in the same location.
With the second one I recieve:
Your browser does not support vector rendering. Currently supported renderers are:
SVG
VML
I use Firefox Version 3.0.3
Any help would be appeciated
Best regards,
Dirk
Am Sonntag 16 November 2008 schrieb Christopher Schmidt:
> On Sun, Nov 16, 2008 at 07:53:17PM +0100, Dirk Umlauffd wrote:
> > I'm sorry, but the example uses KML Files (xml) and not plain textfiles.
> > http://openlayers.org/dev/examples/kml/sundials.kml
> > Could you please provide a correct example?
> Change "Format.KML" to "Format.Text". There is nothing specific to KML
> about that example.
> I'll also add that I would *highly* recommend not using the
> OpenLayers-specific non-standard Text Layer, which no other application
> can consume, and instead use some standardized format like KML or
> GeoJSON.
> Regards,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081117/a646c95b/attachment.html
