[OpenLayers-Users] DrawFeature and FeatureAdded event
Lehtonen, Mika mika at digikartta.net
Tue Nov 25 03:39:13 EST 2008
In addition, there's no problem if the strokeWidth is set to zero;
triggering works. But after I add some, triggering stops working unless
dragging has also taken place.
- mika -
Lehtonen, Mika kirjoitti:
> Yep,
> I can confirm that there's probably a bug. I had a style with
> 'strokeWidth = 0', so I didn't see what happened. If I add some
> strokeWidth, I have same problem. And if you test, those points
> disappear after you have drawn a "real polygon".
> - mika -
> Sture Dingsøyr kirjoitti:
>> Hi Mika and Eric...thanx for quick response :-)
>> Have published an example on http://www.avinet.no/bugopenlayers/openlayers-2.7/examples/modify-feature.html
>> Have added a control button to draw the regular polygon.
>> ...if the user just clicks (no mouse movement between up and down) the feature is added to the layer, but the featureadded event is not triggered (should produce a javascript alert)..
>> So the problem is that the featureadded event does not fire in this case.
>> Have added events to both the layer and control...and it sems to me that in none of the cases the event is triggered.
>> Try the example...(just click in the map).
>> Sture
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
