[OpenLayers-Users] DrawFeature and FeatureAdded event
Lehtonen, Mika mika at digikartta.net
Tue Nov 25 03:34:01 EST 2008
Yep,
I can confirm that there's probably a bug. I had a style with
'strokeWidth = 0', so I didn't see what happened. If I add some
strokeWidth, I have same problem. And if you test, those points
disappear after you have drawn a "real polygon".
- mika -
Sture Dingsøyr kirjoitti:
> Hi Mika and Eric...thanx for quick response :-)
> Have published an example on http://www.avinet.no/bugopenlayers/openlayers-2.7/examples/modify-feature.html
> Have added a control button to draw the regular polygon.
> ...if the user just clicks (no mouse movement between up and down) the feature is added to the layer, but the featureadded event is not triggered (should produce a javascript alert)..
> So the problem is that the featureadded event does not fire in this case.
> Have added events to both the layer and control...and it sems to me that in none of the cases the event is triggered.
> Try the example...(just click in the map).
> Sture
