[OpenLayers-Users] Transparency for WMS layers cached with
GeoWebcache
springrider
springrider at hotmail.com
Thu Oct 9 11:00:31 EDT 2008
Good afternoon,
I am trying to setup some transparency for a layer which is cached by GWC.
This is my code:
var options = { maxExtent: new OpenLayers.Bounds(-180,-90,180,90),
units: 'degrees',
projection: "EPSG:4326",
maxResolution: 0.703125
var map = new OpenLayers.Map('map',options);
var wms = new OpenLayers.Layer.WMS("All Areas","/figis/geoserver/wms?",
{layers:'fifao:FAO_DIV',
format:
'image/jpeg'},{buffer: 0, isBaseLayer: true, wrapDateLine: true, singleTile:
true});
var wms3 = new
OpenLayers.Layer.WMS("Countries","/figis/geoserver/gwc/service/wms?service=wms",
{layers:'fifao:UN_CONTINENT',
transparent:true,
format:
'image/jpeg'},{buffer: 0,opacity: 0.85,isBaseLayer: false, wrapDateLine:
true});
var wms_continent_background = new
OpenLayers.Layer.WMS("Background","/figis/geoserver/wms?service=wms",
{layers:
'fifao:ISO3_COUNTRY',
format:'image/jpeg',
transparent:true,
"cql_filter":"ISO_3='EUR'"},{buffer: 0, wrapDateLine: true, isBaseLayer:
false, singleTile: true});
map.addLayer(wms);
map.addLayer(wms3);
map.addLayer(wms_continent_background);
map.zoomToMaxExtent();
In that configuration, FAO_DIV and ISO3_COUNTRY are the only layers to be
displayed.
When i remove the transparency option for the UN_CONTINENT layer, the map is
correctly generated but FAO_DIV which is my base layer can only be seen
partially:
http://www.nabble.com/file/p19900780/Untitled-2opy.jpg
I really need to have this UN_CONTINENT to be transparent. I know it can be
done.
Could someone tell me how to put this layer which is cached by GWC as
transparent in my configuration?
Thanks a lot in advance
Sylvain
OL 2.6
Geoserver+GWC:1.7-RC3
Oracle Locator DB
View this message in context: http://www.nabble.com/Transparency-for-WMS-layers-cached-with-GeoWebcache-tp19900780p19900780.html
