[OpenLayers-Users] Error retrievin data with Ajax
ajohnson at ecotropolis.com
Thu Oct 9 17:17:35 EDT 2008
Rodrigo, do you mind telling me which versions of Tomcat and Apache you
are using? I can't seem to get this to work and I think it's because I'm
using Apache version 2.2.3
Best regards,
Amy
> Hi Amy!
> You can install the jk-connector... wich is a Tomcat connector...
> This connector will make your apache "talk to" tomcat (or the geoserver
> istance of it... see documentation:
> http://tomcat.apache.org/connectors-doc/)...
> I've got the same problem a little time ago and installed Apache + Tomcat
> JK_Connector and it works fine...
> Oh.. there're still some errors in my geoserver configuration, because
> some
> parts
> of it only works on port 8080.. but to solve exactally your problem, this
> should work!
> Regards,
> Rodrigo
> Rodrigo C. Antonialli
> Rio Claro - SP - Brasil
> LinkedIn: http://www.linkedin.com/in/rcaprofile
> Contato: (19) 9757-0370
> rca.cirdan at gmail.com
> rcantonialli at gmail.com
> Skype: rc_antonialli
> On Wed, Oct 1, 2008 at 14:49, <ajohnson at ecotropolis.com> wrote:
>> I getting the following error:
>> Access to restricted URI denied" code: "1012"
>> when trying to retrieve information from a WMS. I have the whole thing
>> set
>> up on my machine, but I am making the Openlayers request through Apache
>> (on port 9000) to Geoserver running on Tomcat (port 8080). I researched
>> the error and I am getting it because I am trying to retrieve
>> information
>> from a different domain than I am calling from. Is there a way around
>> that?
>> Thanks,
>> Amy
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
