[OpenLayers-Users] control order of requests made
Eric Lemoine eric.c2c at gmail.com
Fri Oct 10 03:01:13 EDT 2008
You may be hitting the browser's maximum number of HTTP requests to
the same host.
What you could first try is set buffer:0 in the options passed to your
baselayer constructor. This will reduce the number of tiles to load
and can therefore improve the situation. This comes with no guarantee
as the number of loaded tiles also depends on the size of your map
div.
To increase the number of parallel requests one common solution
involves assigning multiple hostnames to the server host (in the DNS)
and pass an array of URLs to the layer constructor.
Hope this helps,
Eric
2008/10/6, Matthew Atkins <Matthew.Atkins at loyola.com>:
> Hi List,
> I have a basic map setup which brings in 2 WMS services (layers) from
> the same machine where one is tiled and the other is untiled. The
> problem that I am experiencing is that the tiled (base) layer is having
> to completely load before the untiled layer request is even made and
> then displayed.
> I would like to have the top layer show as the background tiles are
> loaded. Is there a way to control this in OpenLayers or is this
> potentially more of a web server related issue?
> Regards,
> Wally Atkins
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
