[OpenLayers-Users] Problem with Trac notifications
Eric Lemoine eric.c2c at gmail.com
Sun Oct 19 07:53:52 EDT 2008
You may also get notifications if the reporter field includes your
email address. For this to work it may be that the
always_notify_reporter must be set to true in the trac configuration,
and I don't if that's the case in the OpenLayers trac configuration.
Chris, do you know?
And I don't know if it's possible to configure trac so that reporters
are automatically notified without having to put their email addresses
anywhere.
Eric
2008/10/19, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
> Yes, but shouldn't it be the default?
> If a user adds a ticket, there will usually be a follow up question,
> and the user will most likely be interrested in any progress on the issue.
> Not sure how it works, but other Trac systems do this automatically,
> eg. MapGuide, FDO, and Google Code.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Eric Lemoine skrev:
>> Yes. If you just want to receive messages of a specific ticket add
>> your email to that ticket's CC: field. Eric
>>> Then I will recieve all messages generated by the trac system?
>>> It's a bit much for following a few issues, but alright.
>>> Eric Lemoine skrev:
>>>> Hi. Have you registered to the trac mailing list? If not go to the
>>>> OpenLayers list registration page and register to trac at openlayers.org.
>>>> Eric
>>>>> I'm having some trouble with the Trac notification system.
>>>>> I only get email notifications when I write a message on a ticket
>>>>> myself.
>>>>> If others respond to a ticket that I created, there is no notification.
>>>>> I have used other Trac systems before without this problem.
>>>>> Can I modify something to fix it, or is it meant to be that way for OL?
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
